1 - 20 of 47 Posts
One of Keith Code's articles is titled "crashing" and in it he says, "Riding errors which lead to crashing follow distinct patterns. Once detected they can be used to make huge leaps forward in skill and confidence."
What do you he means by "distinct patterns"? What kinds of errors do you think can indicate whether or not someone is on the path to crashing?"
The article can be seen here:
Crashing - Articles by Keith - Cornering Forum
Laws of physics will dictate what causes a crash. How each rider violates these laws will be different. Having crashed twice on the track (one with CSS, another on my own). I got to learn about the limits the hard way >:) sometimes it's rider error, other times it's environment or equipment (rain, new pavement, cold tires, etc...). But at the end it's a rider's responsibility to be environmentally aware.
Errors are easy to spot if someone is about to crash. But a distinction needs to be made whether it's a one-off error or a repeated error. For example, on the track I find myself experimenting with shifting/braking techniques. If someone sees me they would say I'm going to crash. But I'm intentionally making mistakes to see what works best for me.
Red flags would be any of the below in a repeated fashion:
wrong line into and out of a turn.
bad vision, not seeing what's coming. Bad reference point, etc...
choppy on brakes/throttle/clutch.
body position (crossed up, etc...).
Overly aggressive riding/passing. Ambition outweighs skill :D
Physical readiness. Tired, lack of focus, etc...
A crash will be inevitable when any of the above is combined.
Dylan Code posts here...maybe he'll expound...
I think that the prompt is asking about identifying distinct patterns that leads to your own crash.
I have only crashed on track, and it was because I had no fear to push the limits (riding kayo 125gp). I brake later and later until I blow the turn, then back off a little. I get on the gas sooner and sooner until it gets squirrely, then back off a little.
Looking back at the crashes, the chunks I took (chunk = each time I brake a little further) are too big which pushes me past limit of adhesion. Too big a chunk and you can't recover in time before hard parts touch.
Taking my time, only pushing the limit little by little, small chunks, takes me to the limit more gradually so that once I cross it the slip is small and manageable and...dare I say...ADDICTING!!!!!!!
I like that term CHUNKS. I never used the term with racing, but I can relate. I was a big chunk guy when I raced. After one particularly large chunk in turn one, (Portland) I also learned my lesson.
Lots of room for error on that turn, seemed like I slid, rolled, tumbled for minutes.
Maybe Code is referring to things like fixating on a target that you feel like your going to hit (and then hitting it), not looking where you want to go, or going rigid on the handle bars instead of loosening up and letting the bike self stabilize.
User name checks out
After reading the article (good, by the way), I'll take a shot at answering the OP's question - remembering I've only been coaching about 3 years (and I'm too old to go race), so take it with a grain of salt.
To me, crashing normally falls into two categories:
1. Technical: By this, I mean both the bike and the rider. There are certain laws of physics that the bike is accountable to, i.e. setup, tires, heat, temp, track surface, etc etc. Riders have to be able to spot that and take corrective action. For example wayy too much lean angle on street tires on an off camber turn. Rider - may include body position, heavy handed brake or gas, etc etc. A good coach can spot these and hopefully make the correction before it's costly to the rider.
2. Mental: This one is the really difficult one to teach (and for many, harder to learn). A rider that either has the "I (or my bike) can't do it" or the opposite "go for it I'm bulletproof" mentality; the former will get them to not relax and tighten up, usually resulting in going wide and running off the track - while the latter usually results in a low or high side (or worse) because the rider is using up 101% of their existing talent. Both are equally difficult to train a rider out of.
I personally fall into the overly cautious category. I doubt myself and my bike way too much. However, that's kept me to a total of 3 crashes since 2009 at the track. Two of them were Technical (cold tire on wet day) and one was in my first year when I tightened up and ran off the track. And I can still feel myself tense up on those spots at each track. Each rider has their own pace they are comfortable at progressing..some have to be encouraged (like me) and some have to be held back for their own safety. I am a firm believer in baby steps and a slow progression to build rider confidence - as they learn more about their bike (technical) and themselves (mental) they make progress. I am grateful to those patient coaches who helped me - and those that still do because you never stop learning. My coach and mentor tells me "you may have to give up some of your strong survival instinct - smartly - and take some risk to progress" and I agree with him.
I am also a USPA (United States Parachute Association) Instructor with 25 years and 2500 jumps worth of experience. I've seen the same thing play out in skydiving. Usually the cautious but persistent ones tend to stay in the sport the longest. The "go for it" types usually get really good, really quick, then the "your ambition outweighed your talent" moment happens, and they are hurt (or worse) and out of the sport. I had to see a few people pay the ultimate price before I gained a healthy dose of respect for the sport. I'm probably overcautious in the track because 'crashing' in skydiving has an entirely different consequence.
Would enjoy feedback from the OP and experienced coaches.
@ skydiver.
I think your reasoning is fairly spot on but as opposed to gross movement such as consciously jumping off a perfectly good plane is a bit different from fine motor movement that required to operate a motorcycle. Each manipulation has a causal effect to the bike's overall attitude and traction.
One are that most ignored areas in any training program is the physiological and human performance side of the operator.
skydiver, your analysis on the Technical and Mental side is some great insight but from my perspective the missing component in any high risk activity is the basic act to "relax". Just this simple act is actually quite difficult to some folks to obtain and I have observed this from new riders to experienced ones.
In fact it is much harder to teach a new rider to learn to operate a motorcycle safely versus teaching advance techniques to a student who has or currently rides. I compare teaching a new rider to sculpting a fine detailed statue from a large piece of limestone versus an experienced rider that just needs some buffering out.
I'd disagree a little. Stepping off the edge is the easy part, you have no idea how much fine motor skill it takes in THREE dimensions to fly - even holding yourself flat and stable - let alone some of the more difficult maneuvers - because NONE of it is in the range of human experience...hardest thing I ever learned.
Lastly, my experience is mostly teaching novice and intermediate riders - Once they get to Advanced they have learned much of what I spoke of, and that's when the 'fine-tuning' comes in, and is pretty much at the point I'm at in MY riding....
I'd disagree a little. Stepping off the edge is the easy part, you have no idea how much fine motor skill it takes in THREE dimensions to fly - even holding yourself flat and stable - let alone some of the more difficult maneuvers - because NONE of it is in the range of human experience...hardest thing I ever learned.....
You know what? You're right and I stand corrected.
You do need fine motor movements in falling to mother earth at terminal velocity. >:)
PS: I did parachuting when I was in the military so I know what you mean.
I am also a graduate of the Fort Benning school for boys ('93). Parachuting and skydiving are almost entirely two different things. It's not really falling as much as it is FLYING, as you can move, relative to others, in three dimensions, all controlled by how you hold/place/move your body in the airflow. But thank you. And thank you for your service.
It is indeed much more difficult than it looks, although I have nowhere near your experience. After years of hang-gliding, parasailing, ultralight aircraft, and hundreds of hours in fixed wing aircraft I expected sky diving to be intuitive. It is not. :) I can only imagine how challenging formation work must be.
It also is a good deal more physical work than I anticipated and, at least for me, one uses muscles not normally worked much at all.
In addition getting students to relax, when coaching performance driving I often need to disabuse them of thinking driving fast depends on courage or some type of bravery, and the willingness to push the car to its limits. It is instead much more cerebral and deliberate than they expect. Finding the limit is actually pretty easy. :)
Sorry again skydivr I meant skydiving is the activity I did. It was an on-base rec activity.
My wife is the pilot, I tried it - the taking off part was easy, but I got discouraged in the landing part :)
1 - 20 of 47 Posts
