1 - 2 of 2 Posts
I just purchased my GS911 and this is the error code that was on my bike. Is there anything I need to be concerned about? Only change is K&N air filter, everything else is stock, owned it since new.
Fault Codes : 1
10313 : Exhaust flap servomotor
Currently present : NO
Symptom : No signal or value
Engine warning light (MIL) : NO
Frequency count : 64
Logistic(Healing) count : 39
..Fault Code History :
....Record number : 0
....Odometer : 19338.0 mls
....Exhaust flap servomotor status : 129 ....Throttle valve angle relative to throttle valve stop : 3.52 % ....Engine RPM : 1440.0 rpm ....Speed : 0.0 mls/h ....Record number : 1 ....Odometer : 19382.7 mls ....Exhaust flap servomotor status : 129 ....Throttle valve angle relative to throttle valve stop : 3.52 % ....Engine RPM : 1360.0 rpm ....Speed : 0.0 mls/h ....Record number : 2 ....Odometer : 20456.5 mls ....Exhaust flap servomotor status : 129 ....Throttle valve angle relative to throttle valve stop : 3.52 % ....Engine RPM : 1360.0 rpm ....Speed : 0.0 mls/h
Its just the rear exhaust servo. If it doesn't have a full system and has the stock exhaust then the cables may need adjusting or the motor on the exhaust valve is seized. Its not a major concern really. Try and clear it and see if it returns. The fault is not current. Just a history record.
1 - 2 of 2 Posts
