1 - 3 of 3 Posts
Changing plugs, I found this. Should I buy new one or will this one still work? As you know, they go in and out so tight, dont think it will make any difference.
Your thoughts?
209967
You better get 4 new coils since you can get them off ebay in sets for really cheap. I would not use that coil again.
your gasket in the valve cover is not sealing very well to have that much oil residue on the coil shaft area. Oil can build up inside that spark plug hole and if you get enough, it might move to the side of the plug shaft and provide a path to ground if you have any spark bleed out of that coil. So at lean angles you get a misfire like you have been experiencing is possible.
I have seen alot of oil inside an spark plug hole area on a blown engine I brought off ebay.
1 - 3 of 3 Posts
