1 - 1 of 1 Posts
If your clutch switch tabs are bent it can cause a few issues. Your cruise control will not work. Your quick shift also won't work. It normally happens when you fit different levers to your bike and the little arm on the clutch lever bends the tabs upon fitment. They can be straightened depending on how bad they were bent. Sometimes replacement is needed. You should hear 2 clicks when pulling in the clutch lever. That lets you know both are working other than a visual inspection.
1 - 1 of 1 Posts
