If your in Australia and are chasing some Brembo Rotors, JWmotoparts help me out without fuss. I was contacted and told that Brembo only sent me 5 bolts not 10. So some Titanium bolts from ProBolt Australia were sourced. Very happy the quality and the weight difference between the OEM rotor and Brembo is noticeable when holding in hand. The only issue I had was a slight rubbing of the abs sensor, which turned out to be my wheel slightly out of alignment. Very easy to fix by tapping the axle nut in. Hope this helps. Original rotors had done 44000kms with about 30 track days
