1 - 5 of 5 Posts
Attack rearsets give you all of the meat, with none of the fat, in one elegant package. Each kit comes with everything you need to not only improve your fit on the big BMW, but also – improve shifting performance and feel on the brake pedal.
The rearsets are entirely manufactured using top-quality aluminum that’s all held together, stoutly, with high-quality stainless steel fasteners. And wherever pivot points are found, you get a precision bearing-mediated interface. Quality is of no concern, no matter how much you scrutinize these beauties.
All of this lends well to durability in a crash. The footpegs are engineered to break off at half length, giving you enough room for your foot to purchase so you can finish the race or get home safely. Furthermore, each toe peg is mounted on a pivot joint for extra survivability.
In terms of adjustability, there’s little, really nothing – left to be desired. You get a wide range of peg position possibilities, and also, you can adjust the length of the shifter and brake arms, too. And when it comes time to configure the rearsets to your particular dimension, you may have a hard time doing so while you admire the gorgeously sculpted components. From the backing plates, the carbon fiber heel guard or even the footpegs, there’s nuances that they eye will enjoy everywhere.
You know the routine, give TJ a call on 866.931.6644 ext 817 to get this, or any other Attack Performance component sent straight to your door. Of course, [email protected] or a PM works, too!
1 - 5 of 5 Posts
