1 - 9 of 9 Posts
Anyone here have the Air Tech 5? If so can you please share you likes and dislikes?
Thanks!
Thanks!
It is fantastic though a little heavy. Leave some room in your jacket. No dislikes yet after a few months of wearing it.
Discussion Starter · #3 ·
So no heat issue during hot summer days? My worry is that it might be too hot during summer. I am currently using a Helite 2. No airflow issue with it, but I don't like the tether, cause I forget to buckle it sometime. Also extra tether are $30 each. Having multiple bike make it pricey.
As with any airbag there is no airflow where the bags are. But if you are using a well ventilated jack on top of it it is ok. I live in FL and I sweat a lot using it but I think it is worth it for the protection. The back protector on the tech air race is bulkier than on the tech 5.
I'm turned off by the repack/recharge cost and mailing away. I use a HitAir MLV. I always toss my tether over my throttle grip when dismounting, can't forget it that way! I can repack and recharge at the track if needed, it fits loose and allows abundant airflow around it.
Discussion Starter · #6 ·
Helite suggest tying the tether to the frame so it's not long enough to reach the handle bar.
Helite makes a good product but as I recently found out, if you go for a slide and don't leave the bike, it does not deploy and your ribs still get bruised and broken. I'm going to switch to the Tech-Air 5 as soon as I heal up.
Discussion Starter · #8 ·
That is good to know. Hope you get better soon.
No issues with Tech Air 5 in high temps and humidity (25-35C, 77-95F) when moving. The bag itself is somewhat perforated, so there is some airflow. I didn't have any other AStars garments, but the size seems generous. I wear L under L/54 RST leathers or Rukka L/52 mesh jacket . It's a little bit bulkier than usual back protector since the module sits outside.
I was looking at the RST/In&motion range, which seems to be lighter and field serviceable, but it doesn't protect the shoulders.
1 - 9 of 9 Posts
