1 - 14 of 14 Posts
Hi guys,
Time for another question !
I wonder if it possible to fit the Akrapovic steel headers with the SC-Project CR-T exhaust. Simple as that.
I send some mails to both SC and Akra, and they said that they didn't know for sure, but the CR-T fits the OEM headers, and the akra headers fits the OEM exhaust. Should be good nah ?
My only concern would be with the link pipe from Akra. Seems a bit too long to me...
I've heard some time ago that you could make a custom link pipe for these, but I can't find the post again.
What do you guys think ? If anyone managed to do it, or with any stainless steel headers, some tips would be appreciated.
Thanks !
211195
211194
Have you informed your neighbours of your plan? This will be LOUD. Yes it has been done more than a few times.
Don't worry for them ^^
So do you confirm that it is indeed possible without any modifications ?
if the crt can be fitted as slip on, it will fit on akra exhaust, i have done akra header with standard can.
but if you want 100% answer maybe other members have exact experience.
If you want to fit a CRT to akra headers, you need to purchase the HP4 or general 65mm inlet version, along with their carbon clamp and hanger that attaches in place of the passenger peg. The model made to slip on to the stock headers will not work as it's inlet/outlet are different size/not 65mm.
Hi guys,
Thanks !
Discussion Starter #10
Yeah, it should fit either way, but the akra headers' mid pipe is longer than the original one, so the CR-T can won't be attached I think. I've found this picture of someone here that sold one, titanium akra headers with the CR-T can, and as you can see on the picture it has been obviously cut on the mid pipe section to make it fit.
211241
Discussion Starter #11
Thanks for your answer, haven't thought of this ! Will give it a look :)
Discussion Starter #12
I even asked the motomillion staff how they managed to make a custom full system exhaust with the S1 muffler and the akra headers, and they answered that you need to "mount the muffler and mark the mid pipe". So I guess that means that I'll have to properly cut the mid pipe section so that the CR-T comes at its place.
I realize that i was wrong after knowing the year, what i meant is for K67
Hi guys,
Thanks !
I used a Taylor exhaust with a graves muffler worked out well You might need some adapters off the collector
1 - 14 of 14 Posts
