1 - 20 of 24 Posts
I just want to know when the hell are they going to release the iphone app for the Solo (that they promised two years ago...)
The 2020 protocol shows connecting to the 12 pin data bus. The SOLO 2 DL kit however lists the plug and play cable that has an 8 pin data bus connector???
The port under the driver seat (I forgot what it is called... is provided by BMW to connect the alarm system) is compatible with the cable provided by AIM.
I believe this is just making the support official. Even before this, my AIM Solo 2 DL worked with the bike using the 2015 protocol.
There is an 8 pin plug and a 12 pin plug under the seat. The 2020 protocol uses the 12 pin plug, the 2015 protocol uses the 8 pin plug. The plug and play cable is for the 8 pin plug. I imagine there is a reason the 2020 uses the 12 pin plug, I could tap into the wires, but would prefer to get a mating 12 min connector
What is the 12 pin plug called? I connected the supplied cable with my AIM 2 DL with the DWA connector (8 pin) and AIM 2 DL works with the S1000_2015 protocol selected. From what I am seeing, they are interested in getting the CAN+ CAN- V+ GND lines anyway.
Previous support: https://www.aimtechnologies.com/support/stockecu/BMWS1000RR_103_eng.pdf
K67 support: https://www.aim-sportline.com/download/ecu/stock/bmw/ECU_BMW_S1000RR_MY2020_100_eng.pdf
This is what they are selling as the cable: BMW S1000 RR HP4 Solo 2 DL Cable Only
I am using the 8 pin plug right now with the AIM Solo 2 DL with my 2020 K67
If you read the PDF, you will see that they still just care about the 4 lines (CAN+ CAN- V+ GND)
Do they sell 12 pin cable?
Not that I can see. Seems strange that they would reference the 12 pin connector when they sell a 8 pin cable. Perhaps as Karan mentioned, it does not matter so long as it is getting Can + and Can -. Perhaps the 12 pin configuration has switched power
Please keep us posted. Hopefully this is as simple as they make it seem to be.
I’m currently shopping for a LapTimer right now and was planning on the Solo 2...
AIM support is ****. They can't reply me for 15 business days why AIM Solo DL 2 can read 2D sensor data.
Discussion Starter #17
My experience is different. They always response to my emails. The situation in Italy is a bit difficult the last 15 days. I have the same problem with IRC.
I'm not allowed to contact Italy office unfortunately as they have UK reseller.
Maybe I should try Italians. Do you have their email ?
Discussion Starter #19
As far as I know they have suspended their activities until 3 April but I do not know if this is also for their tech support.
Matteo or Stefano always try their best to help. I am sending you with pm the email.
1 - 20 of 24 Posts
