1 - 4 of 4 Posts
Anyone else experience an ABS pump failure? My brake failure light started coming on, would go away when I restart. Dealer checked and isolated to failed pump. First rideable Sunday all winter and dealer has my bike.:mad:
BMW HP4, when i start the bike, the abs light and tail lights will be constantly on, may i know what is the cause of such issue?
Did you check the ABS button mode? Hold the ABS button down for 4 seconds with the key on. It will start to flash. When you move forward 5 meters it will go off. If it does not then most likely there is a VSS error. Do you have a GS911 to scan codes?
1 - 4 of 4 Posts
