Has anyone installed the Abs module cover from Alpha Performance?
I'm looking to change my brake lines to straight the calipers. I've been having problem with my brakes for the past two years and i'm going to see if bypassing the ABS pump will fix my problems. (I've been getting spongy feeling in the brakes after 2-3 laps on the track and never was able to get a confidence inspiring feeling from the lever. I changed pads, fluids, manual bleed, vacuum bleed, Always with the same result)
Is there anything else that's needed to retain the DTC functions, besides new lines if I order this plate?
alpha Racing ABS/DTC Modulator Cover BMW S1000 RR (2010-2014) ? alpha Performance
Thanks
Thanks
