Glad you had a great experience! I'm having trouble getting hold of
@BMW_388, maybe you can help with some questions I have. Perhaps he's unable to answer because he isn't a vendor here yet. If you're able to help with any of these answers, let me know. I'm trying to decide which way to go with my flashing. These questions were meant for BMW_388 but I'll just direct them at everyone that can answer now. Maybe BMW_388 can PM me the answers?
#1 From my limited understanding of how these flashes are, they are all cookie cutter unless you get a custom dyno tune. BUT if you get a good "cookie cutter" tune, a custom dyno tune should only yield 1% more power. Especially because the 2020 is a wideband bike. You can command a specific AFR and it will nail it every time. Is that correct?
#2 I see the XWorks Flash requires a servo buddy if aftermarket exhaust is installed. Why is that so when other companies are able to provide a flash without a servo buddy and no errors?
#3 I saw your explanation of the idle rough idle with the XWorks flash and the stock idle. The explanation you gave is completely different than what other companies give relating to the nature of this issue. Your explanation seems to be (correct me if I'm wrong) that oil is leaking and getting sucked into the throttle bodies but when I looked at your photos, I saw the throttle bodies are not soaked with oil but clean on the inside where the air would flow to the engine. Other companies are claiming this issue is a result of bad air/fuel mixture at idle to adhere to US standards for emissions. They also provide Air/Fuel charts at idle that place it at 17-18 AFR!! Crazy stuff there. But a flash that will adjust idle AFR seems to work in fixing this issue (from what I've seen but not experienced myself). Do you have any of your own independent testing to confirm your results about this being a hardware issue? Meaning if the oil leak is fixed, the idle is now fixed with perfect AFR?
#4 I'm unable to find on your site or motomillion the testing you did to bring this flash to market. I recall you saying you spend hundreds of hours in R&D. Are you able to provide some videos or data from your own independent testing? Do you have individual cylinder monitoring? What equipment are you using at your shop to conduct these tests? It would be helpful for someone like me who's trying to decide what route to go.
#5 The RCK for the 10-19 bikes seems to be only adjustable to +-4* of timing and +-20% fueling. Why is that? I've seen many people (Irnie Marcel for one) that require piggyback fueling to make this work with aftermarket exhaust and different fuel. Is there a solution BMW provides for greater adjustability?
#6 The RCK or whatever it's called for the 2020 is thousands in cost and doesn't adjust timing at all while disabling knock sensors. That seems very odd to me. Any idea why they are doing this?
Thanks in advance for your response.
