1 - 6 of 6 Posts
Anyone knows if the 2d front suspension sensor installed on a 2016 would work on the 2020 ?
BMW data logger ?
Pitbull restraint system as per pitbull CS they said " we were told it would work" but has anyone actually tried it .
Thanks
BMW data logger ?
Thanks
The TRS works 100% from the K46 to the K67
The 2D sensor works 80%.. as in the sensor itself functions as you would expect it to. the mounting brackets however do not work well. The turning radius is so decreased to the left that it is useless on the street. I mounted it on the front side of the forks using the upper bracket but, changing the lower mounting. This mounting allows 100% left and right steering. It will not be for everyone to do this however.
https://www.s1000rrforum.com/forum/bmw-s1000rr-general-discussion/239590-2020-2d-racing-front-sensor-install-working-not-working-k67-s1000rr.html
1 - 6 of 6 Posts
