Not much, maybe 5-7 turns in the rear and my softer setting is 11, 5C 7R and my harder setting when the fluid is hot is 12, 6C 8R.
I had a shop try to set it up in the winter with the original cat on. It took all preload in front to get 42mm and all preload in rear to get 30mm rear. Did not handle well. When I changed to akra headers it was far too stiff to ride so I progressively let out preload and actually found myself quite close to the lower limit. I was running 8 for compression but when you have someone push on the front and then the rear- you can see how much stiffer the rear is and i think it was overwhelming the front. Tbh I think im right abt 5.5 turns or 5 3/4. I have no idea what the sag number is but I dont bottom the rear often and it feels good. I ran these settings on a fast paced WV trip yesterday on new M9RR and the bike felt as good as ever with 11k miles on it since Feb 2022.
