I am selling my dream trackday/race build and moving on to different things. I've build this bike over the last 2.5 years and had a ton of fun but I just don't get to enjoy it enough and won't have the time to in the near future. This bike is the elimination of all excuses, everything works and well dialed in, just flip the switch and GO!
Build list
2020 BMW S1000RR M-package 6244miles 35500$
1-owner was street bike until 4000miles. Oil changes with Motul every 3-4 track days or one race weekend
Full Akrapovic Evolution TI exhaust
Sprint filter
All airbox restrictions and secondary air valve plumbing deleted with Alpha parts
Airbox and under tank wrapped with Teknofibra heat shield
RS2E V2022 Competition flash with ABS and DDC delete (meaning NO check lights on the dash!) split throttle bodies and ignition cut TC
This is THE best flash or alternative to the MOtech ECU
Alpha Racing short throw throttle
Alpha Racing left and right button pods
Alpha Racing ignition delete
Alpha Racing quick shifter/ autoblipper
Alpha Racing gear position sensor
Ohlins FKR fork internals with 10.75 spring rate, serviced this year
Ohlins TTX rear shock with 110 spring
Alpha racing rear shock linkage
Full Steve Weir chassis geometry and suspension valve setup performed by Daredevil
Ohlins steering stabilizer
IMA triple tree with all adjustments
IMA roller bearing upgrade for triple tree
Alpha Racing Clip ons
Alpha Racing Rear Sets
Alpha Racing Fairing stay
Alpha Racing short lightweight subframe
Alpha Racing Full Carbon race plastics
Alpha Racing race seat
Alpha Racing frame sliders
Alpha Racing steering stops (smaller ’street’ version)
Women-Tech dash cover/protector
MRI windscreen
Carbon fiber tank extender be SE carbon
Ilmberger Carbon frame covers
Ilmberger Carbon swingers covers
Ilmberger Carbon rear fender cover modified for faster wheel changes
Ilmberger Carbon wiring cover
Fullsix Carbon kickstand
Custom M1000RR style graphics kit without any logos
Alpha Racing reinforced clutch cover
Alpha Racing Clutch cable and linkage
Suter clutch basket with new clutch and steel plates for 2022 and zero race starts on them
Galespeed Ultimate clutch perch
Alpha Racing GB racing engine covers
Brembo GP4-MS front calipers with braktech SS caliper pistons
Brembo EVO 17x18 master cylinder (matched to calipers by brembo)
Brembo P2 34 rear caliper with fresh brembo pads
Stahlbus speed bleeders on every bleeder location
Brembo Z04 brake pads front
WRS brake cooling ducts
Alpha racing 6mm brake discs front
Alpha Racing floating brake disc rear
Alpha Racing Thumb brake kit
Alpha Racing GP remote brake adjuster
Spiegler Custom ABS delete brake lines with Staubli quick disconnects front
Spiegler custom brake line rear
TWM underslung rear brake caliper bracket made captive
Brembo brake reservoirs with custom mounting brackets
Custom made axle blocks with precise measurements to be able to flip blocks for one tooth rear sprocket swaps
Alpha Racing spec OZ forged aluminum racing wheels with extra rear wheel
Renthal 520 rear sprockets 2x40 tooth and 2x41 tooth
Alpha Racing 520 front sprockets
DID chain with 3 track days on it
Evotech axle sliders front and rear
Alpha Racing spec Samco hoses
Alpha Racing radiator cap
Alpha Racing radiator reservoir overflow
Alpha Racing fuel cap
New Spark plugs this year
Valve adjust performed by Tad at Calmoto 3 trackways ago (all were in factory spec)
New OEM M lithium battery this year
OEM BMW radiator and oil cooler guard made to fit race plastics
Most items already safety wired for club racing use
Clean and clear title with bike on non-op status
Any questions please feel free to PM me or ask away.
Build list
Sprint filter
MRI windscreen
