By any chance is there a FA location to unlock the top speed in the display?Curious, did you plug it in and try?
You can try FA: X709A Speed limitationBy any chance is there a FA location to unlock the top speed in the display?
I emailed them and they said:Curious, did you plug it in and try?
On e9x platforms, it's the PWM values that is coded to change DRL brightness, or auto dimming when headlights are active. I have not messed with F vehicles and I never noticed the DRL dimming when my headlights are on. Not sure if it's because I have LED's headlights or not. But if you have esys and FDL coding capability, then it's something to explore.I just realized this the other day... On most vehicles, when the headlights come on, the DRLs dim a certain percentage so as not to create glare. When the DRL option is enabled, it doesn't seem as if the DRL go to a "full brightness" when the headlights turn off. There must be another setting that needs to be changed in order to get that
if (headLight == off) {
drlBrightness = 100;
} else {
drlBrighness = 70;
I know that the coding isn't Java-like, that's pretty much what I'm looking for.
Can you tell what is need to do this?Coded my DRL lights in today @WingZeroX5 . Works great.
1. Laptop or PC with Windows 10Can you tell what is need to do this?
Thanks for posting this. I am going to try and validate if ENET does indeed work. I think @WingZeroX5 had mentioned that it won't because the bike does not have a GW capable of ENET. I don't remember very clearly and might be mistaken though.1. Laptop or PC with Windows 10
2. ICOM Next (I think an ENET cable can be used but I used a ICOM Next)
3. Ethernet cable
4. Power supply unit
5. E-Sys
6. PsdZ data pack. Lite or Full. Or if you have ISTA then just link the psdz folder to the same one as ISTA.
Mm, I never said ENET won't work, I said it might. But I never tried because I have the ICOM. You can certainly use an enet cable and give it a go.Thanks for posting this. I am going to try and validate if ENET does indeed work. I think @WingZeroX5 had mentioned that it won't because the bike does not have a GW capable of ENET. I don't remember very clearly and might be mistaken though.
What is a good reliable place to get the PsdZ Lite pack/E-Sys/ISTA? Last time I was upgrading ECUs on my 330i, I got it from some forum sticky (download was from Mega, iirc.)
Thanks. Thats the intent. But reading a few others forums, people are very confident the bikes dont support ENET.Mm, I never said ENET won't work, I said it might. But I never tried because I have the ICOM. You can certainly use an enet cable and give it a go.
I see the ICOM Next A is about 300 on ebay with various cables. What's the cost on on the E-Sys software and PsdZ data pack?1. Laptop or PC with Windows 10
3. Ethernet cable
5. E-Sys
People have warmed me about these being duplicate. I also thought the ICOM Next A cost $600+I see the ICOM Next A is about 300 on ebay with various cables. What's the cost on on the E-Sys software and PsdZ data pack?
A genuine ICOM is $600+, comes with two cables: Yellow 15 ft (iirc) ethernet and the OBDII.I see the ICOM Next A is about 300 on ebay with various cables. What's the cost on on the E-Sys software and PsdZ data pack?
Heya benny,I bought a aftermarket 10 pin cable ICOM D cable. Not as much of an issue with a cable.
