1 - 20 of 32 Posts
Has anyone tried any of the Vortex or Woodcraft Clip-Ons and confirm if they will fit on this bike? I’m dying to get rid of the stock bars but I don’t want to drop a ton of money on the Gilles or Alpha that hasn’t been released yet
Welllll I went ahead and bought the two piece woodcraft 55mm clip ons. I will report back and see if they fit in a couple of days. Go me for being a pioneer.
Good for you! Interested in how it works. Do the 2 piece clip-ons mate up to the stock triple?
I have Alpha Racing clip-ons in stock if you are interested.
The woodcraft clip ons should work if the correct ones are ordered. Remember you need the top triple end clamps to have a complete kit.
You can get riser ones which will put the bars at the same height as the stock ones as well.
There are Alpha Racing and Gilles Tooling options out there which are made specifically for the 2020 S1000RR.
Gilles Tooling Clip Ons for 2020 S1000RR
Alpha Racing Clip Ons for 2020 S1000RR
Damn wish I saw this earlier. They are still developing clip ons I believe...they should be out soon. I do not think the old ones will work, but I didn't talk to Eric about it (they might work as Motomillion pointed out if you close off the triple tree).
Discussion Starter #11
Mani! Can I get those Alpha Racing buttons?!
Discussion Starter #14
I’m having a slight issue with fitment on the alpha racing clip ons with the OEM brake master. The bleeder valve hits the upper cowl on the fairing.
Any ideas?
You can order a different MC steel line that comes with a different angle.
Or suck it up, get a Brembo MC, and a new hose with it.
I recommend coreMoto, they make one of the best brake steel lines. You tell them what angle you want line to fit MC, length, 3 days later you have it in the mail. Have their lines on R1 and R6.
For clipons, I have tried many of them. Evol and Attacks top the list. In that order. Same for rearsets and brake guards.
Discussion Starter #17
I have to run an OEM master cylinder for Superstock races or I will get disqualified if anyone contests me. The figment ok the Alpha stuff is fantastic I just have to figure this out.
If I angle the bars way in they fit but then I lose my wide bar angle.
Discussion Starter #18
Why change the clip-ons? What's the advantage?
There are a few advantages to running clip one on this bike.
1. You get adjustability. I get to decide how much angle I want on the bars and height.
2. The OEM bars are expensive to replace.
3. When you crash with the OEM bars the seem to have a tendency to fold into the fork and will bend the fork instead of snapping.
just a tip for you guys. you need to order the correct clip-on. There is a problem with using the original triple clamp. there is a screw ( the one to fasten the half moon part) that will stick out under the triple clamp. this will not let you put the clip-on flush on against the bottom of the tripple clamp.
So the Alpha racing and the Gilles clip-on is "shaved" and rased on the correct spott to prevent this.
Discussion Starter #20
Did you have any clearance issues with yours?
1 - 20 of 32 Posts
