I have a buddy (not a forum member) who has an 18' S1000RR 11,800 miles. This past week his bike has been giving him issues. He brought it to my house and we used my GS-911 to check it out and got the following:
0x3A15A1 - Knock Control, Knock Sensor 1, no signal
0x480B8F - Front ESA Suspension Damping Adjustment short circuit
04x480B82 - Failsafe Leve 5: Hardware Failsafe.
I rode the bike and the engine seems to run fine, I'm assuming that Knock Sensor 1(not sure if its the right or left sensor) is on its way out if it hasn't completely failed already. He's gonna order both and replace them both, may as well I think.
The DDC codes are a real concern. The system has defaulted to the stiffest settings making it very uncomfortable to ride(I'm assuming this is the Failsafe Level 5: Hardware Failsafe code). We weren't able to calibrate the suspension using the bike's controls BUT I was able to calibrate the rear travel sensor using my GS-911. I'm wondering if there's an issue with the front fork sensor(the internal one. he's not running a 2D front travel sensor) that's causing the Failsafe. Is it possible to change that? Would the whole fork have to be taken apart? Is it worth doing that or just getting new/used forks? Is there a way to troubleshoot the DDC suspension? Does anyone have a wiring diagram with specifications i.e. resistance readings, voltages, etc?
Should we just assume the front forks should be replaced?
Thanks in advance for any input, advice, etc.
