1 - 19 of 19 Posts
· Registered
Actually, after I made the post I found it. I even have an email from Danmoto stating they weren't making a 15-16 model so I haven't check since then till last night. Good to see it's available.
· Registered
2017 S1000RR
I am a bit confused. The Danmoto site lists a BMW S 1000 RR 2015-2016 Conical GP Full System exhaust system for $360.00. Does this seem right?
Craig
· Registered
2017 S1000RR
Junk, or can a bung be welded?
· Registered
don't want to highjack the thread, but another cheap alternative is to get one on ebay 'mid pipe link' from china. The seller is hunter. Paid 170
The exit is a little large, so the stock exhaust won't fit. Had an aftermarket exhaust and this didn't fit either, need to check the dimensions. But one way to fix this is either use an adapter or take it to a weld shop to make adjustments.
I had a 2012 muffler and put that on it which fit well.
The stock exhausts have a weak point right at the y joint. So if the bikes does go down, it always bends there and the stock muffler then touches the swingarm.
· Registered
2017 S1000RR
Thanks for your input. I have a 2017...not sure if a "mid pipe link" would even work with this year...thoughts??
Craig
1 - 19 of 19 Posts
