1 - 10 of 10 Posts
So this is where the added power has come from revised runners in the head different cams and different velocity stacks can it be done Will the cams fit in a 14 head or would a complete 15 motor fit in a 14 and would it require a different ecu.
If you can get them at a crazy good steal give it a try. If you have to buy at or close to new price walk away fast!
If i needed more power on my 14 and most of the basic mods were done already (start there if not) Then i would look into putting some aftermarket cams and parts on the top end from a good company.
I would guess that you could make more power from aftermarket 2014 cams then the stock 15 cams.
Yeah it was more out of being curious than anything and then i realized it would also require a new exhaust as well since the 15's exhaust has changed. I figured all this stuff would start showing up on ebay shortly at very reduced prices. Sometime i think too much :grin2:
I have heard nightmare about aftermarket valve springs and valves dropping so I am very nervous about that.
SpeedRR, i wasa thinking of swopping a 15 head as well on my hp4. haha
With regards to exhaust headers, i have a buddy who ran a 10-14 akra full system on his 2015 s1000rr. lathe off about 2mm on each of the exhaust runners will fit into the 2015 S1000rr cylinder head
Discussion Starter #10
bumping this thread as i came across a great deal for a 15 head throttle bodies and airbox. There has to be a tech on here that would know if it will fit and if they will work
1 - 10 of 10 Posts
