1 - 10 of 10 Posts
I’ve parted out my 2010 BMW S1000RR with 16,149 miles and have sold a lot of parts, including the engine but have the remaining items. These parts will fit 2010-2011, most likely up to 2014 years and limited on fitting 2015-2018 years. All items are in great used condition. Buyer will pay actual shipping cost and I’ll ship international too. If you see a part in the pics that I didn’t price and you’re interested in it, let me know!
Frame with clean/clear title. No issues at all!: $2500
Zero Gravity Dark Smoke screen: $60
Zero Gravity Clear screen: $50
OEM Rear Shock with 16149 miles: $50
Sidestand with plug: SOLD
Attack Performance Rearsets: $350
OEM muffler: SOLD
Exhaust/muffler heat shield: $30
Left and Right side gas tank plastic cover: $30 each
Airbox/ECU gas tank cover in OEM “Shine Yellow” (2011 color): $30
Airbox with all sensors: $60
Instrument cluster with 16,149 miles: $400
Ignition key set with gas tank cap and lock, rear seat lock and ECU with 16,149 miles: $600
**Purchase instrument cluster and ignition key set/ECU together: $800
Horn: $5
Ohlins Steering Damper (Dampener?): $200
Rear brake master and reservoir: $30
Cooling system hoses (left and right side): $20
Sprocket cover with metal guard: $10
Oil Cooler (small radiator thing): $100
Right Brembo brake caliper: SOLD
Main engine wiring harness: $80
Sub engine wiring harness: $80
***purchase both wire harnesses together: $120
Radiator fan: $80
Bosch OEM Traction control module: $15
Rectifier/Regulator: $25
Chain guard: $10
Rear swingarm fender: $20
Swingarm: $60
Rear ABS sensor wire: SOLD
Right front fork “refreshed” 7/2019: SOLD
Left front fork “refreshed” 7/2019: SOLD
ABS pump module: $25
ABS brake lines (all): $30
Dog bone swingarm bracket: $15
Pazzo Shortly levers with master/reservoir and clutch perch: $180
O2 Sensors: $25 each
Rear Rim with rotors and ABS: $300
Front Rotors: $80 each or both for $140
4 ignition coils: $50 each or all 4 for $150.
209512
209513
209514
209515
209519
209516
209517
Do you have the handlebar combination switches? run/start on one side, turn signal etc on the other
1 - 10 of 10 Posts
