Surprising amount of carbon build-up on intake valves - BMW S1000RR Forums: BMW Sportbike Forum
post #1 of 13 (permalink) Old 05-03-2012, 09:06 AM Thread Starter
While I was putting on a bracket to reduce the throttle tension yesterday, I opened the throttle valves & was very surprised to see quite a bit of carbon build-up on the intake valves. Those closest to the center were the nastiest with significant build-up near the base where the stem joins the valve. I run a PC V with Dan's map, and always run premium fuel (93 octane here in NC) so I am wondering what could be causing this, especially with only 4,500 miles on the bike. In comparison, my highly tuned C6, with close to 60k miles looks almost new.
I poured some Techron Complete Fuel System Cleaner into the tank & will do so over the next 2 fill-ups as well (12 ounce bottle @ 4 ounces per fill-up). I hope that cleans this up as it looks like it could easily affect performance.
I plan on taking the bike to a local tuner soon to check the AFR & get a custom map created.
djhartm is offline
post #2 of 13 (permalink) Old 05-03-2012, 10:10 AM
S1000RR ROB's Avatar
get some pics mate, in all honesty a bit is quite normal...
S1000RR ROB is offline
post #3 of 13 (permalink) Old 05-04-2012, 09:39 AM
dattaway's Avatar
High octane fuel burns slower. And leaves carbon behind, which increases compression...and hot spots...requiring more high octane...
dattaway is offline
post #4 of 13 (permalink) Old 05-04-2012, 10:35 AM
Burning slower has nothing to do with leaving carbon behind. The simple answer is he's running rich. A proper tune at any octane should have minimal carbon.
Zed03 is offline
post #5 of 13 (permalink) Old 05-04-2012, 10:48 AM
dattaway's Avatar
It's just my experience taking apart an engine that used excessively high octane has a layer of nasty carbon to be removed from the head.
dattaway is offline
post #6 of 13 (permalink) Old 05-04-2012, 01:14 PM
Administrator
Sal R1's Avatar
Would you agree that a modern engine running factory tune & using a higher octane gas than it was designed for would leave carbon behind?
Sal R1 is offline
post #7 of 13 (permalink) Old 05-04-2012, 02:04 PM
the OP was talking about valve deposits.
what brand fuel are you using? even though most gasoline in an area come from the same refinery they don't have the same additives.
I use chevron or unocal 76.
took the intake off a bmw (car) with 100k+ miles. valves were almost clean. very minimal deposit. no additional additives were used.
techron or redline fuel system cleaner does work. I've used them in the past.
fast4d is offline
post #8 of 13 (permalink) Old 05-04-2012, 03:22 PM
My experience that even well-running engines will sometimes have these deposits, regardless of fuel or cleaners. I had an early R6 that had significant carbon on the intake valves that ran great and had a true 155 mph top end, so if it was affecting performance it wasn't by much.
I think it stands to reason that if you jet your bike strictly for throttle response and performance, you're probably more likely to be running with excess fuel and this excess fuel is probably going to increase carbon deposits. Whether it is significant, I don't know.
I doubt octane has diddly-squat to do with it. There are rumors that higher-octane fuel has a better additive package, but I'm skeptical that the difference is significant enough to buy higher-than-required octane gas for this reason alone.
Personally, I wouldn't worry much about it. Of all the fuel/additives, I've seen enough data to think that Techron is probably the best, and perhaps the only way that really does much for this problem, but it works better to prevent deposits rather than remove them.
markjenn is offline
post #9 of 13 (permalink) Old 05-04-2012, 04:20 PM Thread Starter
Running out in the mountains, I'm forced to use whatever stations have premium, but I try to stick with top-tier fuels. I would say it's probably 50/50 top-tier/no-name gas.
djhartm is offline
post #10 of 13 (permalink) Old 05-08-2012, 10:42 PM
Just as a recommendation, checkout Sea Foam for your engine cleaning/fuel delivery system cleaner...IMHO it is much, much better than techron.
Red and Alpine White 2012 S1000RR, Austin Racing Full Inconel GP2R exhaust with titanium can, PCV with dyno tune by WSB tuner, AR CF Satin Belly Pan, R&G Racing side covers and wheel sliders and License plate relocation kit with rear light internal LED blinkers and brake lights.
usrodeo4 is offline
