2010 vs 2012 + RCK harness - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
  • 1 Post By BMW_388
post #1 of 5 (permalink) Old 09-12-2019, 08:21 AM Thread Starter
Slaki's Avatar
So I am sure a bunch of guys will be able to help here, but also just asking @BMW_388.
I have a 2010 S1000rr which someone went and placed a 2012 clock/Dash with a flashed RCK ECU in. Bike starts, but runs BAD!! Over fueling, does not want to idle, etc.
I know that the harness will work with the engine as I have done it before, but does the 2010 harness work with 2012 clock/Dash and ECU? Is it just a bad flash?
I have noticed that the harness part numbers differ, but thought that it was only the Heated grips and knock sensors?
2010 wiring harness part number: 61117724592
2012 wiring harness part number: 12518527765
2013 S1000rr track bike
Slaki is offline
post #2 of 5 (permalink) Old 09-12-2019, 08:28 AM Thread Starter
Slaki's Avatar
Sorry for the double post, but the flashed ECU was flashed with RCK 2 for the Gen 2 models. Will Throttle body have anything to do with the issues?
Slaki is offline
post #3 of 5 (permalink) Old 09-12-2019, 10:14 AM
BMW_388's Avatar
The harness is completely different that the cluster plugs into. I call it the chassis harness. The protocols for the 10/11 cluster are different from the 12-14. I have seen the cluster cause the throttle bodies to move just plugging and unplugging from the harness. The reason is the CAN BUS. So, if you are having fueling issues, it could be the CAN BUS is not running clean with data and the ECU is not working the throttle bodies correctly.
Slaki likes this.
Riding and loving my 2020 K67 with the custom XWORKS ECU
Check out MotoMillion ( forum Vendor section ) for all your needs in ECU work
Check out MotoMillion also has programming for RCK3 / HP power Kit enables now
Programmer for MotoMillion is myself ( BMW_388 )
I personally own the 2014, 2015, 2018, 2020 S1000RR
This makes for checking my ECU work is perfect every time sold by MotoMillion
BMW_388 is online now
post #4 of 5 (permalink) Old 09-12-2019, 03:03 PM
speedfinn's Avatar
Just to make sure, reset adaptation and TPS adaptation done?
2011 s1000rr track bike inc. rck2 k-techDDS DunlopKR
speedfinn is online now
post #5 of 5 (permalink) Old 09-13-2019, 02:49 AM Thread Starter
Slaki's Avatar
I did yes. Ended up with the same story as this again. https://www.s1000rrforum.com/forum/e...-no-start.html
Swapped over to another set of throttle bodies now.
Took the dash, ECU and ignition out of the 2010 last night and will try on a 2013 to see if it does the same. If it does, then either ECU or Dash is faulty, if not, then it is the harness that I need to replace in the 2010 to a 2012 to accommodate the dash and ECU
Slaki is offline
