2013 --- on dash issue - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
  • 1 Post By BMW_388
post #1 of 5 (permalink) Old 05-14-2019, 11:33 AM Thread Starter
Slaki's Avatar
Can anyone tell me why the dash does not show 0? Instead it shows --- until you pick up speed. I am waiting for the GS 911 to check error codes
2013 S1000rr track bike
Slaki is offline
post #2 of 5 (permalink) Old 05-14-2019, 03:27 PM
Does it still show the mileage ridden (odometer?)
skapan is offline
post #3 of 5 (permalink) Old 05-15-2019, 05:18 AM Thread Starter
Slaki's Avatar
It does yes. Everything works except for the ---. As soon as the bike moves, it works fine
Slaki is offline
post #4 of 5 (permalink) Old 05-15-2019, 09:28 AM
BMW_388's Avatar
This is interesting.
The --- indicates it is reading a NULL value. Typically a VSS sensor is broke. Lets think that maybe you changed a tire recently and upon replacing it back, you have hit the VSS sensor. The VSS picks up the rotation of the ABS ring so it is working enough to display the speed. However, how much distance is it taking now? If all is working correctly you should only have to roll 5 meters for the VSS to pick the rotation and turn off the blinking ABS light, and speed is displayed. If you are rolling much further than that before the ABS light trips off, and the display changes from the --- to whatever speed it starts at, then you are dealing with a bad sensor either front or rear.
Bad thing about intermittent type information from a sensor is that the diagnostic code does not set, and no warning is displayed there is an issue in the self check modes.
Remove the wheels and inspect the sensor ends. Look for bad chipping. It is even possible you when down a gravel road and a small rock was fling up off the tire and just happen to land right on the ABS rotating ring and the rock went between the sensor and ring enough to slightly damage it that way.
Slaki likes this.
BMW_388 is offline
post #5 of 5 (permalink) Old 05-16-2019, 05:17 AM Thread Starter
Slaki's Avatar
Thanx for that.
Update:
Issue fixed. During a crash, the wiring in the sub frame got damaged. Fixed it all up and is working again.
ID:	200416   Click image for larger version
Slaki is offline
Similar Threads
Oil Pressure Issue Hp 2013 Adam BrzeziŇĄski New Members "Must Start Here" 2 09-08-2018 09:55 PM
2013 sporadic DTC issue kanwisch BMW S1000RR General Discussion 7 08-22-2017 08:57 PM
alpha perfomance dash installation issue ghostrr1000 S1000RR/HP4 Electrical, Lighting, Wiring, Battery issues 14 04-14-2016 10:12 PM
New Member- 2013 with R&G no cut frame slider issue pharo New Members "Must Start Here" 5 04-20-2015 11:32 AM
BMW HP4 model 2013 Quickshifter issue alfredob New Members "Must Start Here" 5 12-11-2014 02:16 AM
