Quickshifter Issue's the top of 4th & 5th gear. - BMW S1000RR Forums: BMW Sportbike Forum
 5Likes
post #1 of 26 (permalink) Old 12-08-2016, 04:52 PM Thread Starter
dalvin00100441's Avatar
Just the past month I noticed when I was at the track I was unable to quick shift up at high rpm's to 5th & 6th gear sometimes. Now it's happening more often. Wondering what could be the issue on my 2015. I have already done the shift link recall long before this started.
dalvin00100441 is offline
post #2 of 26 (permalink) Old 12-08-2016, 05:33 PM
BMW_388's Avatar
I am not sure 100%, but I think once the QS adaptive values set in the ECU, they stay even if they are not working out very well.
so that might mean you need to reset the current adaptive values and restart the QS process to get some better working values in there.
The dealer can remove adaptive values. The GS911 can reset adaptive values.
I dont think that removing the negative cable works on resetting adaptive values however. it will reset DTC's , but I am pretty sure it does not reset the adaptive values.
Mine was having issues before an oil change time and i had the dealer reset my values. Once I did the relearn it worked alot better 4 5 6 ... my 1 2 is still so bad I hate it. Big lag time between 1 and 2
BMW_388 is online now
post #3 of 26 (permalink) Old 12-08-2016, 05:59 PM
sbs
sbs's Avatar
I had the EXACT same problem and it was a minutely rounded off shift star.. Also, are you running a stronger than stock shift star spring?
My dealership took 3 tries to find the issue and it was the eagle eye of their master mechanic who figured out it was the shift star. Once replaced, ZERO issues.
Cheers.
dalvin00100441 and eagle734 like this.
2015 Ducati Panigale 1299S, Termi Carbon front exit slip-on with Cat delete, RapidBike Race module, Sprint WSBK race air filter..
2011 BMW S1000RR, full Ti Akrapovic, OpenFlash tune, Vortex rearsets, Pazzos shorties, Brembo Superbike rotors, Galfer 1375 ceramic race pads.
2011 Triumph Daytona 675R.
sbs is offline
post #4 of 26 (permalink) Old 12-09-2016, 12:05 AM
Torchsport's Avatar
Location: 90 minutes from Brainerd International Raceway, Minnesota
Factory rearsets?
**Current bikes**
'18 Yamaha YZ250FX
'16 BMW S1000RR Premium (Red/White)
'15 MV AGUSTA BRUTALE 1090RR (Another Red/White!)
'14 Yamaha Zuma 125
Torchsport is offline
post #5 of 26 (permalink) Old 12-09-2016, 01:16 AM Thread Starter
Cheers.
Wonder the price & if this will be covered under warranty. I do have over 32k miles on this bike so this could be it. I'm using lightech rear sets but switched the shifter rod and lever parts back to stock. The multiple times of changing myself and dealer on the shift star may have contributed to this.
post #6 of 26 (permalink) Old 12-09-2016, 12:30 PM
sbs
sbs's Avatar
This is the shift star, in case you don't know what it is.. It's the star under the green circles
[IMG][/IMG]
sbs is offline
post #7 of 26 (permalink) Old 12-10-2016, 08:35 AM
Salt flats's Avatar
Common issue
This is a very common issue, I encounter it at most racing environment type situations. Usually at full throttle it will hang up 3-4 or 4-5, an most common when using auto blip. There are 2 other riders on S100RR, an all 3 of us discuss this issue. I was discussing this with Brock ( Brock's performance ) at the Mojave Race last April. He said the one thing he found on his personal S100RR, was to run the chain tension a little on the tight side. It seems to have made difference for my bike this year at Bonneville, still had it happen, just not as often.
2014 HP 4 # 3681 Topspeed 204.6 MPH
2006 k1200LT daily rider
1998 Road King. Sold w/ 63k
1976 Kawasaki 900 LTD. Crashed in1981
1972 Yamaha DT 250. School transport
1970 Yamaha DT125
Rupp Roadster
God made all men, Sam Colt made them equal !
Salt flats is offline
post #8 of 26 (permalink) Old 12-10-2016, 12:01 PM
z00
z00's Avatar
1- Have you had the shifter arm recall done? Dealer replaces it for free
2- It's mostly either the shifter star, or shifter rod/springs. You need to take it to the dealership, have them open the clutch box and look at it. Like in SBS's pic.
2015 s1000RR (dead)
2016 R1
>10K club president.
z00 is online now
post #9 of 26 (permalink) Old 12-11-2016, 02:03 AM
Salt flats's Avatar
Which bikes
What years were included, I new there was a recall, just didn't think my bike fell under the parameters. So to answer your question no recall done.
1970 Yamaha DT125
Rupp Roadster
post #10 of 26 (permalink) Old 12-11-2016, 02:29 AM
z00
z00's Avatar
On 15+ there a recall. There is a long thread on it I started last year.
2015 s1000RR (dead)
2016 R1
>10K club president.
z00 is online now
