Fork Oil change: DIY! - Page 11 - BMW S1000RR Forums: BMW Sportbike Forum
 109Likes
post #101 of 159 (permalink) Old 02-14-2018, 03:03 AM
A B
A B's Avatar
Originally Posted by Unknowns1krr View Post
Thanks OP for the great write up!
Iíll be doing this job as well as soon weather warms up in South Korea.
I read on other threads donít touch the clutch side pinch bolts ? Is this true ?
Yes, the lhs pinch bolts are not touched, they hold the socket that the axle fits into.
Sent by Shoephone using Tapatoe
1990 Carrera 4 | 2016 S1000RR | 2010 S1000RR (gone)
A B is online now
post #102 of 159 (permalink) Old 02-26-2018, 03:04 PM
stratus's Avatar
I am stuck on putting back the dust cup (new).
The RDS manual says to use a special tool to push the dust cup in. Are all just using their fingers? I can't push it in
stratus is offline
post #103 of 159 (permalink) Old 02-26-2018, 06:36 PM
oz14's Avatar
You should be able push it on. Use a little seal grease to aid it going in (said the actress to the bishop).
You can use a piece of PVC over the fork leg and seat it with some more force, just make sure the end is square, free of any sharp edges.
Sent from my iPhone using Tapatalk Pro
stratus likes this.
2017 Yamaha FZ-09
2014 HP4 Comp #4547
oz14 is offline
post #104 of 159 (permalink) Old 02-27-2018, 05:09 AM
bennymx's Avatar
A plastic tool or screw driver can be used to lightly tap it into place. That's bushy but it will get it done. Normally you just compress the fork all the way down and knock it in that way before the fork is assembled.
stratus likes this.
bennymx is offline
post #105 of 159 (permalink) Old 02-27-2018, 05:20 AM
stratus's Avatar
thank you, will give it another try tonight.
I did put some fork oil around the edge of the seal, but will try to put some on the tube as well... the manual says to use the special tool, hence I thought it can't be done without it, but will try again
stratus is offline
post #106 of 159 (permalink) Old 02-28-2018, 07:33 AM
stratus's Avatar
nope, it goes in with one side, the opposite popping out.
stratus is offline
post #107 of 159 (permalink) Old 02-28-2018, 10:54 AM
oz14's Avatar
Are you sure the seals are in the correct way around and seated in far enough for the spring clip to seat in the groove?
5150 Pops likes this.
2017 Yamaha FZ-09
2014 HP4 Comp #4547
oz14 is offline
post #108 of 159 (permalink) Old 02-28-2018, 03:30 PM
stratus's Avatar
it is the first time I am doing this, so NO, I am not sure.
But it looks like even I if have the problem you mentioned, the dust cup should go in at least one millimeter, but NO, it does not go it at all...like it is almost too large
stratus is offline
post #109 of 159 (permalink) Old 02-28-2018, 03:53 PM
oz14's Avatar
Is the spring clip seated?
Did you buy new dust seals or reuse?
2017 Yamaha FZ-09
2014 HP4 Comp #4547
oz14 is offline
post #110 of 159 (permalink) Old 02-28-2018, 05:00 PM
5150 Pops's Avatar
A few pictures could go a long way to understanding exactly what you are thinking is wrong.
There very well could be confusion over terminology, on either side...just thinking out loud here.
stratus likes this.
2015 KTM SDC 1290R
2015 S1000RR - DDC
5150 Pops is offline
