Oil window indication - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
post #1 of 17 (permalink) Old 08-31-2013, 11:37 AM Thread Starter
How much oil is represented by the upper and lower levels on the oil window? My oil was at the top of the window after last oil service (1400 miles ago) and is now at the halfway point. How much oil use does this represent, and when would you add oil? Thanks.
flyrider is offline
post #2 of 17 (permalink) Old 08-31-2013, 11:53 AM
doidera00's Avatar
I think i put a cup or a little over of oil after about 2k
Sent from Motorcycle.com Free App
doidera00 is offline
post #3 of 17 (permalink) Old 08-31-2013, 12:01 PM
Rainman's Avatar
What? It's right there in your owner's manual.
Look in the Technical section near the back.
Now go look.
On the street - 2/5/10.
Rainman is offline
post #4 of 17 (permalink) Old 08-31-2013, 02:21 PM Thread Starter
Now go look.
Got it...0.8L between min and max. Thanks for making me look. Just curious...at what level do you, personally, deem it necessary to "top up" your oil, Rainman...?
flyrider is offline
post #5 of 17 (permalink) Old 08-31-2013, 05:15 PM
Rainman's Avatar
Glad you found it !!!
I try and keep mine no lower than half way up the upper half, and ideally close to the bottom of the red circle at the top in the window, which they mark as MAX. (Top of the red circle at the bottom is what they mark as MIN).
I estimate my ideal fill ranges are about 1/4".
Personally, I check every time I put the bike on the rear stand to clean and lube the chain (about every 500 miles or 3 weeks when dry, sooner if wet on the street). and I add approx. 6 oz, or 1/5 quart, or 0.18 liters back when it's at 1/4" down. At the track, I check the level every other session just to make sure nothing has gone sour. I do use more oil on a track day, and with about 18k miles on the engine, I think I'm putting no more than a half a quart in between oil changes @ roughly 3k miles. I don't really keep track of that.
Everybody's bike goes through oil at different rates, so check and figure out what your usage is over time.
The reason I check on the rear stand is the bike has to be perfectly vertical to read the window correctly. Try this. Read the glass on the side stand and note where it is. Then try and hold the bike vertical and stoop down to read the glass again. Whoa, that's hard or uncomfortable for me to do. So put a piece of 2"x4" under the side stand and hold it down with the left bar as you go down to look again. The level will be significantly lower.
Always do a final check when the oil is hot, not cold or even warm. Be very careful when refilling or topping off. Since from say middle to top mark of the glass is less than half a quart, if you overshoot the top of the glass, you've overfilled, and you can't see by how much. I do it in short stages and let sit a bit before looking again.
That's my $0.02.
Rainman is offline
post #6 of 17 (permalink) Old 09-01-2013, 03:33 PM Thread Starter
Good info, Rainman. I took a good ride this morning, got the bike good and hot (fan came on as I neared home). Level was 2/3 up in window vs 1/2 up in window cold.
I'll probably add 1/4 quart of oil soon...when the indication is 1/2 up the window when hot. That won't get me to MAX, but I'd rather be around 3/4 full than overfull...err on the side of caution, as you do.
flyrider is offline
post #7 of 17 (permalink) Old 10-02-2013, 01:38 AM
Guys,
Just out of curiosity, the maintenance manual speaks of changing oil with bike on side stand. Does that mean you fill it to the upper mark in the viewing window with the bike on side stand?
Can I fill it to the upper level whilst bike is on bike stands?
I am curious to find out if BMW have engineered the viewing window such that people without stands can service their motorbike?
wudka is offline
post #8 of 17 (permalink) Old 10-02-2013, 02:30 AM
Rainman's Avatar
Originally Posted by wudka View Post
Guys,
Just out of curiosity, the maintenance manual speaks of changing oil with bike on side stand. Does that mean you fill it to the upper mark in the viewing window with the bike on side stand? NO
Can I fill it to the upper level whilst bike is on bike stands? YES
I am curious to find out if BMW have engineered the viewing window such that people without stands can service their motorbike? YES
I'm not sure what source you are referring to by "maintenance manual".
I have a paper 2010 Rider's Manual (US Model) that came with the bike when new, and a DVD Repair Manual (USA) (1st edition, 06/2010).
In my Rider's Manual, on page 107 in Section 9 titled "Maintenance" is a topic called "Engine Oil" and a subtopic of "Checking engine oil level". At the end of this subtopic is a paragraph with three bulleted items. The first bullet says "Make sure ground is level and firm and hold motorcycle at operating temperature vertically". Bizarre wording, but I take that to mean the bike needs to be perfectly vertical and horizontally level to read the appropriate oil level in the sight glass. It says nothing about filling.
The next subtopic is titled "Topping up engine oil" and it has 6 bullets.
None of these bullets mention either side stand or bike stands. The first bullet says the ground should be level (assume horizontally) and firm, and to "park" the motorcycle. The fifth bullet says "Checking engine oil level (-> 107)." which refers you back to the previous paragraph mentioned.
So recapping,... you can add oil while the bike is on side stand or bike stands, but when it comes to checking the oil level it must be level in both horizontal and vertical planes. To get vertical, you can use a block under the side stand (like I mention in post #5), or put the bike on wheel stands.
Make sense? and welcome.
Rainman is offline
post #9 of 17 (permalink) Old 10-02-2013, 10:41 AM
HOG SLYR's Avatar
Oil level should be checked with the bike on level ground with the bike upright. The use of a rear stand, un-level ground and not being perfectly upright will effect what you see in the window and ultimately your oil level.
2019 BMW K1600GT
2011 BMW S1000RR
2005 Honda ST1300a
HOG SLYR is offline
post #10 of 17 (permalink) Old 10-02-2013, 12:07 PM
The bike does need to be basically level in both roll and pitch, but I don't think we need to start getting out carpenter levels or worrying whether a rear stand affects the pitch enough to throw off a reading. Basic common sense here.
markjenn is offline
