Horn Not Working - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
  • 1 Post By Thessfy
post #1 of 9 (permalink) Old 06-12-2012, 09:06 AM Thread Starter
koolcaymancops-S1krr's Avatar
Horn Not Working
Anyone having problems with their not working, since my left switch started giving problems i can seem to get my horn to work, i checked the fuse but it looks ok, might be the connection at the horn itself, any advice will be grateful
Mark.
11' Motorsport S1KRR (Totaled)
08' Ducati 848 (Current project)
06' Suzuki GSR 600 (Sold)
koolcaymancops-S1krr is offline
post #2 of 9 (permalink) Old 06-12-2012, 09:54 AM
dattaway's Avatar
I'd wiggle those exposed connectors on the horn. They are always ripe for surface corrosion.
dattaway is offline
post #3 of 9 (permalink) Old 06-12-2012, 05:24 PM
BAZ
BAZ's Avatar
It's the switch had mine done under warranty, mine not their first.
BAZ is offline
post #4 of 9 (permalink) Old 06-12-2012, 07:00 PM
prev1's Avatar
My 2011 stoped working intermitently and then stopped altogether. Warranty item, the left handle bar control.
prev1 is offline
post #5 of 9 (permalink) Old 06-12-2012, 07:00 PM
evl_twn's Avatar
Any cracks on the switch housing?
evl_twn is offline
post #6 of 9 (permalink) Old 06-12-2012, 07:11 PM
prev1's Avatar
no cracks, everything is like brand new. just failed and apparently it is common.
prev1 is offline
post #7 of 9 (permalink) Old 01-22-2019, 09:18 AM
My horn is not working all of a sudden. When pressing the button on the left handlebar, I hear the relay click under the rear seat. I checked the fuse and the 7.5A fuse is good. Relay is clicking.. sounds like it is good. I measured voltage when checking fuse and proper voltage is being applied. I will go in and check the connections at the horn and check for voltage to the horn before I look at replacing the horn. If I do need to replace the horn, does anyone have recommendations for a louder horn that will fit? I live in S. Florida and a loud horn could just save my life.
Thanks all.
robleewent is offline
post #8 of 9 (permalink) Old 01-22-2019, 01:55 PM
z00
z00's Avatar
I use the horn to holler at shorties.
Check fuses, connections to horn, and battery terminals. Finally, switch where horn button is needs to be checked. Those switches are known to go bad.
2015 s1000RR (dead)
2016 R1
2017 R6 (track)
>10K club president.
z00 is online now
post #9 of 9 (permalink) Old 01-23-2019, 07:33 AM
You all writing about checking the switch or the wiring's...my original horn also did not work anymore suddenly and I also checked the switch and the connections and the wiring thousand of times.
Until a fried asked me if I also have already checked the horn membrane. No sooner said than done: the membrane of the horn is full of moist and dirty...
robleewent likes this.
Thessfy is offline
