BMW Bosch ECU - how it works - what you need to know - Page 33 - BMW S1000RR Forums: BMW Sportbike Forum
 157Likes
post #321 of 324 (permalink) Old 05-27-2019, 06:03 AM
bennymx's Avatar
bennymx is offline
post #322 of 324 (permalink) Old 05-27-2019, 06:58 AM
DrIoannis's Avatar
Model is 2010 so I only have fuel mixture (and maybe ignition) as you mentioned.
In the following pic I have Hand throttle and ECU throttle. ECU throttle it is never 0%. Only hand throttle is 0%. In the fuel table the throttle I think is the ECU throttle. Do how can I manage engine brake if it is not in 0%? And also is it supposed to be like this with the hand and ecu throttle?
DrIoannis is offline
post #323 of 324 (permalink) Old 05-27-2019, 07:37 AM
speedfinn's Avatar
Engine brake mixture is created from the actual throttle valve angle. For example, if throttle valves are 5% open, you must modify the mixture correction factor for throttle angle 5%.
Throttle valves are always open even if twist grip is 0%.
For example with RCK2 flash in 2011 ecu, and minimum engine brake setting throttle valves are open (when twist grip is 0%):
3%@6000RPM
6%@9000RPM
9%@12000RPM
So in this case I should modify 0%, 5% and 10% mixture correction factors if I want to fine tune engine brake.
DrIoannis likes this.
2011 s1000rr track bike inc. rck2 k-techDDS DunlopKR
speedfinn is online now
post #324 of 324 (permalink) Old 06-12-2019, 11:23 PM
This post is filthy with some awesome info. Thx guys
bennymx likes this.
scott747!! is offline
