Fork Clip-on Size - BMW S1000RR Forums: BMW Sportbike Forum
LinkBack Thread Tools
Old 04-16-2011, 05:23 PM Thread Starter
Fork Clip-on Size
Just in case anyone was in any doubt as to what size clip-ons are needed with the S1000RR, I can tell you that it's 55mm.
I know this as I (and others on here, who influenced my purchase) bought some 52mm Renthal clip-ons and tried to install them today, only to find they were too smaller. A digital caliper showed the fork size as 55mm. Doh!
So, anyone looking for any 52mm clip-ons, unused?
On a positive note, it's possible to adjust the standard clip-on's so they're lower down the fork and more flared out, as seen below. This makes the bike easier to control for me, as I'm further over the front and there's a bit more leverage to turn-in.
ID:	5118   Click image for larger version
Amethi is offline
Old 06-19-2019, 09:01 AM
Hi,
I'm following up on this threat after finding it on Google.
I have a 2013 and I've been told by several people that it is not possible to adjust (open, in my case) the handlebar. My goal is to have them more "open"/further away from the tank, which is what I believe you did.
I heard rumors about "a pin" that holds the clip ons in place and makes it impossible to adjust. Your post is one of the very few places where it says the opposite, so I'd love to confirm you can actually open them up a bit more.
Thank you.
tf1000rr is offline
Old 06-19-2019, 09:27 AM
Slaki's Avatar
At the bottom of the top steering, there is a hole where the pin of the standard clip on goes into, so the only way you will be able to "open up" the standard handlebars is by either grinding off the pin or move the standard clip-ons further away from the steering like they did in the previous post.
With aftermarket clip-ons you can adjust the way you want...
Photo attached
2013 S1000rr track bike
Slaki is offline
Old 06-19-2019, 09:38 AM
Photo attached
Thank you very much! Really cool to be able to visualize this.
If you don't mind ... Do you know how much needs to be "opened" to have clearance for the pin? Based on the original post, it doesn't seem like a huge difference from OEM.
tf1000rr is offline
Old 06-19-2019, 09:40 AM
It also seems that lowering the clip ons is a good "trick" to have clearance for the pin to not interfere, right?
tf1000rr is offline
Old 06-19-2019, 09:41 AM
Slaki's Avatar
I would say roughly 8 - 10mm. If you loosen the bolt of the OEM clip on, you will be able to slide it down the tube. You will feel when you turn it side to side when it no longer engages.
Slaki is offline
Old 06-19-2019, 09:44 AM
Slaki's Avatar
Just remember that when you lower the clip on, you change your "geometry", which means that you will have a different feel on the bike. 10mm wont make too much of a difference on the road, so if you dont want to grind the pin off or change to aftermarket parts, then I would say yes to your question
Slaki is offline
Old 06-19-2019, 10:58 AM
Site Sponsor
the_gooch's Avatar
Just Dremel off the pin.
the_gooch is offline
