Servo buddy when installing exhaust on 2020 - BMW S1000RR Forums: BMW Sportbike Forum
 4Likes
  • 1 Post By BMW_388
  • 2 Post By BMW_388
  • 1 Post By BMW_388
post #1 of 10 (permalink) Old 07-18-2019, 10:01 PM Thread Starter
Koenigsberg's Avatar
I’ve been soooo busy with work but am finally nearing my 650 miles to get the limiter taken off. I plan to install my akra full system Sunday.
So, does the 2019 servo buddy work with 2020? Doesn’t look like they have one for a 2020 yet. What have you guys done that already have full exhausts installed?
Thanks!
1989 BMW E30 M3
2013 BMW S1000RR
Koenigsberg is offline
post #2 of 10 (permalink) Old 07-19-2019, 12:50 AM
BMW_388's Avatar
Originally Posted by Koenigsberg View Post
Iíve been soooo busy with work but am finally nearing my 650 miles to get the limiter taken off. I plan to install my akra full system Sunday.
So, does the 2019 servo buddy work with 2020? Doesnít look like they have one for a 2020 yet. What have you guys done that already have full exhausts installed?
Thanks!
this one works. its the one I have tested and using
https://www.woodcraft-cfm.com/produc...57-servo-buddy
SimonUK likes this.
BMW_388 is offline
post #3 of 10 (permalink) Old 07-19-2019, 12:57 AM
Fbto's Avatar
Is this a must have for the full Akrapovic for the 2020? And I guess we need 2? And we can use the 2018 version?
2020 BMW S1000RR M (Street)
2013 BMW HP4 #2710 (Street)
2013 BMW S1000RR (Track)
2013 Suzuki DRZ400SM (Everything)
2013 BMW HP4 #0162 (STOLEN JUNE 17, 2014!!!)
2019 F150 SCREW LARIAT
Check out my IG Page... S1000RRGram
Fbto is offline
post #4 of 10 (permalink) Old 07-19-2019, 01:04 AM
BMW_388's Avatar
Only one on the K67
The code in the ECU works different from the code on the K46. It counts the ignition cycles of test on the module to flapper. With it gone, it will not throw a code for at least 5-10 ignition cycles. The Servo Buddy keeps the counter from missing. I need to find that counter in there and see if I can stop it.
I have only tested the Woodcraft one.
BMW_388 is offline
post #5 of 10 (permalink) Old 07-19-2019, 01:09 AM
Fbto's Avatar
Originally Posted by BMW_388 View Post
Only one on the K67
Cool. Can someone provide some details on where it should be installed. Assuming there are multiple spots it can be installed?
Fbto is offline
post #6 of 10 (permalink) Old 07-19-2019, 02:17 AM Thread Starter
https://www.woodcraft-cfm.com/produc...57-servo-buddy[/QUOTE]
Thank you! I just ordered this one off of revzilla. Should be here Monday. Hopefully just a day of the cables being loose to do their thing won’t set a code. I plan on getting my ecu flashed by you soon as well.
1989 BMW E30 M3
2013 BMW S1000RR
post #7 of 10 (permalink) Old 07-19-2019, 09:09 AM
BMW_388's Avatar
Just zip tie it to the module bracket like this. the cable is long enough in that it is easy to connect and then work the zip tie on the bracket and the servo module.
Fbto and bennymx like this.
BMW_388 is offline
post #8 of 10 (permalink) Old 07-19-2019, 11:14 AM
V3rbatim's Avatar
So you bought the servo buddy for the 2018 s1000rr model?
V3rbatim is offline
post #9 of 10 (permalink) Old 07-19-2019, 11:25 AM
Illusionalta's Avatar
As per the akra instructions, youíll just remove the cables, and leave the servo installed, bike wonít know the difference
Illusionalta is offline
post #10 of 10 (permalink) Old 07-19-2019, 12:59 PM
BMW_388's Avatar
Just buy this part number and it works.
There are several versions out there, and this one works to avoid the ignition cycles. The flapper code itself is off, and you will not get a engine light for some time, but after about 5-10 ignition cycles it will come on without this module in place. I will find the coding for the ignition cycles, but it will be at least 2 weeks.
bennymx likes this.
BMW_388 is offline
