Bike won't shift - BMW S1000RR Forums: BMW Sportbike Forum
 8Likes
post #1 of 26 (permalink) Old 07-14-2019, 01:01 PM Thread Starter
xKtF's Avatar
Bike won't shift
Bike:2014 S1000RR
25K Miles
I was out today for about 4 hours everything was going great, and then out of no where my bike would not shift(I had to stomp on the gear to make it go into first) And if I try to switch to 2nd it just jumps into neutral. The gears work if I use the quickshifter but I can not downshift. I thought it was the detent plate had broke, but I checked it that is fine, what else should I check?
Update:
https://streamable.com/bejwl
Looks like it may actually be the selector shaft
Update: Everything is fixed, turns out it was the selector shaft, so far no false neutrals.
xKtF is online now
post #2 of 26 (permalink) Old 07-14-2019, 05:57 PM
I'd change that spring and put in the new 6 pin selector thingie. There was an update a while back. Are you using 300V? How often do you change it?
skapan is offline
post #3 of 26 (permalink) Old 07-14-2019, 06:20 PM Thread Starter
xKtF's Avatar
I might just do that, also first time using 300V and I just put it in recently. Any idea of what could make the bike not able to switch gears? I also pulled out the clutch and some of the plates were pretty dry is that normal?
xKtF is online now
post #4 of 26 (permalink) Old 07-14-2019, 06:36 PM
No, clutch plates should not be dry, but that wouldn't affect shifting I don't think. Not to start an oil war, but 300V is only good for about 300 miles and then should be changed. Motul 7100 would be a better choice and it's cheaper too.
bennymx, beech and wes4895 like this.
skapan is offline
post #5 of 26 (permalink) Old 07-14-2019, 07:16 PM Thread Starter
xKtF's Avatar
300 Miles ??? Not 3000? And I guess I will go to 7100 After this
xKtF is online now
post #6 of 26 (permalink) Old 07-14-2019, 07:53 PM Thread Starter
xKtF's Avatar
Video is bugged because it was uploaded on my phone, but here is how it jumps out of gear https://streamable.com/tu3pp
xKtF is online now
post #7 of 26 (permalink) Old 07-14-2019, 09:17 PM
Yeah, 300. Pretty hard to make any judgement if you're shifting it without the engine running and the bike moving down the road.
bennymx likes this.
skapan is offline
post #8 of 26 (permalink) Old 07-15-2019, 11:31 AM Thread Starter
xKtF's Avatar
I started it up and still hard to shift. what would be better if I record the gear cluster or the actual shifter when trying to shift?
xKtF is online now
post #9 of 26 (permalink) Old 07-15-2019, 01:33 PM
Just ride it normally and try to explain in detail what's happening. Have you changed anything on the bike recently?
bennymx likes this.
skapan is offline
post #10 of 26 (permalink) Old 07-15-2019, 02:48 PM Thread Starter
xKtF's Avatar
Nope nothing changed, I was out riding for about 4 hours (shifting fine) on the way home it got started to get stuck in gear (hard to switch out of gear.) Is there anyway I can tell if its the selector shaft? Would the damage be very noticeable?
xKtF is online now
