lithium battery on tender? - Page 2 - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
post #11 of 16 (permalink) Old 05-09-2019, 10:24 PM
sro
sro's Avatar
You likely have a stock battery on a previous generation bike, which means it is a lead acid.
Do you know how to take the seat off? It’s usually two screws in the back along the rail.
sro is offline
post #12 of 16 (permalink) Old 05-13-2019, 04:48 PM Thread Starter
lol its a standard battery iam leary of uncorking anythng on this bike without a bmw tech ...i called andthey said its a reguar battery
RR1000MATT is offline
post #13 of 16 (permalink) Old 05-14-2019, 02:34 AM
sro
sro's Avatar
Good thing I asked the question. It’s always good to lean about your bike. Start by reading the manual.
sro is offline
post #14 of 16 (permalink) Old 05-15-2019, 10:41 AM
Carlito's Avatar
Lithium batteries are completely different in chemistry. Either you get a charger specifically designed for Lithium or remove the battery from the bike for long term storage. Lithium has a significantly slower discharge rate than standard batteries. I have a lithium Battery from my R1 which I sold in 2014 and the Battery still measures 13v I may need to check periodically but the key is specifically designed lithium charger.
2020 BMW S1000rr ()
2013 BMW S1000rr (Gone)
2007 Yamaha YZF-R1 (Gone)
2003 Yamaha YZF-R6 (Gone)
2000 Yamaha YZF-R6 (Gone)
Carlito is offline
post #15 of 16 (permalink) Old 05-15-2019, 11:00 AM
GixY2K's Avatar
When taking the seat off or plastic, you just need to be careful not to cross-thread the screws. I don't know about the new bikes, but the 2015 screws and bolt assembly felt to me like they were easy to cross-thread (and made from flemsy metal). I learned after the first one that happened to be the one from the seat; partially due to the fact that it is hard to get a screwdriver in there while squeezing the edge of the seat, causing it to go at an angle and resulting in a cross-thread... :\
2015 S1000RR
GixY2K is offline
post #16 of 16 (permalink) Old 05-15-2019, 11:07 AM
PaniDropper's Avatar
They make many smart chargers now that will properly charge multiple battery types. The NOCO chargers usually can do both, I personally like CTEK over NOCO but I do not think CTEK has a combination charger for AGM/lead/lithium. I do have both a NOCO and the CTEK and both get used regularly.
I also have a Solar PL3750 I use for automotive/heavy equipment batteries. This charger paid for itself (impressive considering it costs over $400) by bringing batteries which literally had no charge back from the dead and passed load tests without issue. Easily one of the best chargers out there, though I would not hook it up to a lithium.
If you just are looking for a cheap tender the company "Battery Tender" makes one that can handle both types (I have 2 of these kicking around and they work very well) -- they also make good, cheap lithium batteries:
https://www.amazon.com/Deltran-Batte...gateway&sr=8-3
PaniDropper is offline
Similar Threads
Rapid Bike and Lithium Battery in the Battery Tray stgatev S1000RR/HP4 Electrical, Lighting, Wiring, Battery issues 17 03-08-2018 02:21 PM
Replacing Stock Battery with Featherweight Lithium OEM Fit Battery - NICE!! HardRacing S1000RR/HP4 Tech and Performance Chat 18 02-04-2018 06:16 PM
Battery Tender - Install Rainman S1000RR/HP4 Tech and Performance Chat 5 07-29-2014 01:15 PM
Battery tender jr questions Nitronut BMW S1000RR General Discussion 5 03-05-2012 03:00 PM
Battery Tender Charging & Storage Systems RidersDiscount Riders Discount 0 02-12-2010 09:48 AM
