Weird idle and stalls after idle[Solved]
Ok so update seems to jerk/stutter under 25 mph after that its normal.[Sounds like a 3 cylinder]
Update: Fixed the issue, I changed out the coils and reset adaption and issue is no longer like it was :grin2:
BMS-KP2
BMS type: BMS-KP2
Controller Type: Engine Controller
Controller: 6020
Part No.: 8543376
Hardware Index: 36
Coding Index: 03
Manufacture Date (YY/MM/DD): 2013-11-05
MCV: 0.6.5
FSV: 0.77.57
OSV: 2.3.1
Manufacturer: Bosch GmbH
HWOE No.: 103174348
Program status: 570I
Date release: ZB10
Factory I-Level: K024-13-08-500
Actual I-Level: K024-13-08-500
VIN model year: 2014
7 fault codes found:
10011 Output stage of Lambda (O2) sensor heating circuit (Cylinder1)
The fault is not present now.
10313 Exhaust flap servomotor
20012 Electronic throttle valve, level 2 monitoring of computed values
10314 Balance-pipe valve servomotor
20000 Throttle-valve servomotor (EGAS controller (initialization))
10019 Output stage of Lambda (O2) sensor heating circuit (Cylinder2)
10124 Intake Air Temperature Sensor faulty
ABS9ME
Controller Type: ABS Brakes
Part No.: 8535415
HW Version No.: D1
Coding Index: 0
Manufacturing Date: 2012-01-15
HWOE No.: 103112628
MCV: 0.6.6
FSV: 1.3.0
OSV: 0.1.0
Variant: K46
No fault codes found
CAN-Kombi-K461
Cluster type: CAN-Kombi-K461
Controller Type: Instrument Cluster
Controller: 6120
Part No.: 8536809
Hardware Index: C6
Coding Index: 02
Manufacturer: Siemens VDO Automotive
Manufacture Date (YY/MM/DD): 2013-11-12
MCV: 0.6.7
FSV: 3.2.3
OSV: 4.2.0
HWOE No.: 103186948
Assembly No.: 8535428
2 fault codes found:
37773 CAN-bus error: No communication with ANY of the other control units (CAN bus Off)
37802 Fuel level sensor
Forget to tell a few things about the bike:
2014
20k Miles
Spark plugs changed
[Recent]
Replaced all ignition coils
Airbox is working
https://streamable.com/n1ggf
https://streamable.com/cxil3
https://streamable.com/ja5c2
https://streamable.com/xt388
BMS-KP2
BMS type: BMS-KP2
Controller: 6020
Part No.: 8543376
Hardware Index: 36
Coding Index: 03
MCV: 0.6.5
FSV: 0.77.57
OSV: 2.3.1
HWOE No.: 103174348
Date release: ZB10
ABS9ME
Part No.: 8535415
HW Version No.: D1
Coding Index: 0
HWOE No.: 103112628
MCV: 0.6.6
FSV: 1.3.0
OSV: 0.1.0
Variant: K46
CAN-Kombi-K461
Controller: 6120
Part No.: 8536809
Hardware Index: C6
Coding Index: 02
MCV: 0.6.7
FSV: 3.2.3
OSV: 4.2.0
HWOE No.: 103186948
2014
20k Miles
Spark plugs changed
[Recent]
Airbox is working
