Flashing ABS and Traction Control - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
  • 1 Post By SimonUK
post #1 of 8 (permalink) Old Yesterday, 09:20 AM Thread Starter
Morning all. Still looking for the right bike and may have found one but I have some concerns regarding the ABS and Traction lights in the cluster. They both flash together when the ignition is turned to on and when the engine is running. I took it for a test drive and cannot rmemember seeing them while I drove.. . too busy watching the landscape blur. Damn these bikes are missiles, I totally get the attraction. Anyway, they just contine to flash when the bike is stationary so that seemed odd to me. Infication of a problem or is this typical? Incidentally, I am told it has a “power commander” installed but as I understand that would be a ecu remapping tool so I cannot see how that could affect the ABS or Traction.
Blessed is online now
post #2 of 8 (permalink) Old Yesterday, 09:32 AM
The ABS self test happens when you turn on the ignition and completes after you have travelled a few meters.
BMW_388 likes this.
SimonUK is offline
post #3 of 8 (permalink) Old Yesterday, 09:33 AM
SwissWizard's Avatar
The two lights flashing when the bike is turned on and stationary is perfectly normal. Both lights should turn off once the bike hits like 5 mph, but no cause for concern at this point.
SwissWizard is offline
post #4 of 8 (permalink) Old Yesterday, 11:05 AM
This is the correct answer.
Key on VSS/ABS self test mode, take off and roll 5-10 meters tells the system the VSS is all functioning correctly. If you happen to ever change the rear wheel especially, you can damage the VSS attached to the brake caliper bracket. Then if you happen to loosen the front forks left side bushing and mess up the spacing on the front wheel, this can cause the VSS to not pick up correctly too. So, BMW made the system to self check every time you key off and key back on.
BMW_388 is offline
post #5 of 8 (permalink) Old Yesterday, 08:11 PM Thread Starter
Thanks all. The help is appreciated.
post #6 of 8 (permalink) Old Yesterday, 08:22 PM
btw, it is in the rider manual.
SimonUK is offline
post #7 of 8 (permalink) Old Today, 06:33 AM Thread Starter
I will be sure to get a good read over once I get mine. Seller did not have his handy.
post #8 of 8 (permalink) Old Today, 06:46 AM
You can read/download the owner's manual online. Do not go to a test ride unprepared.
skapan is online now
Similar Threads
Tc, abs flashing and speedo shows 0mph Dc2rb8s5 S1000RR/HP4 Wheels and Tires 1 05-11-2016 10:43 AM
Need Help, Traction Control and ABS keeps going off S1kGuy BMW S1000RR General Discussion 13 12-10-2015 05:33 AM
Can't turn off traction control /abs! alien_rr S1000RR/HP4 Tech and Performance Chat 7 03-09-2015 09:39 AM
WTB: Front wheel speed/abs/traction control sensor AyoPlaya187 Bikes, Parts, Gear, etc. Wanted - WTB 0 07-26-2014 06:10 PM
Will removal of ABS affect Traction Control? George Villar BMW S1000RR General Discussion 17 04-21-2014 12:47 AM
