RACE ONLY SET, STANDARD SHIFT SET OR REVERSE/GP SHIFT SET
YOUR CHOICE OF THE 3 FOR $385 SHIPPED
WOODCRAFT 05-0750B REARSETS COMPLETE KIT S1000RR STANDARD SHIFT
WOODCRAFT CFM 05-0750B BLACK STANDARD SHIFT REARSETS COMPLETE KIT
WOODCRAFT 05-0751B REARSETS COMPLETE KIT S1000RR REVERSE SHIFT
WOODCRAFT CFM 05-0751B BLACK REVERSE SHIFT REARSETS COMPLETE KIT
WOODCRAFT 05-0752B REARSETS RACE SET COMPLETE KIT S1000RR
WOODCRAFT CFM 05-0752B BLACK REVERSE SHIFT & STANDARD SHIFT RACE ONLY REARSETS COMPLETE KIT
Our new
"Race Only" rearsets are designed specifically for top racers to give them the simplest set up possible. We relocated the shift pedal from the rearset bracket to the kickstand mount (eliminating the kickstand) for a quick action direct linkage setup. This gives racers the optimal ratio for high speed/high rpm upshifts while keeping the stock quick shifter intact. The simple design eliminates parts giving you fewer parts to replace if the rearsets are damaged in a crash.
Our rearsets are machined from tough, aircraft grade 6061 T6 aluminum. We chose this material specifically because it provides the best combination of strength and durability. Other grades, such as 7075 generally tend to crack, instead of bend, when they are met with an impact. The use of 6061 allows our brackets to simply bend under stress instead of snapping off or cracking when they are crashed heavily. Rearsets made from 6061 can be often bent straight or even be welded (by a certified welder) whereas 7075 tends simply to crack or break and is much more difficult to weld.
Note: Replacement parts are available under the "Spare Parts" tab.
tom@biohazardcycles.com
Email me with any questions or deals...
ARROW, LEOVINCE, AKRAPOVIC, TAYLORMADE, TERMI, M4, BROCKS, MUZZY, JARDINE, YOSHIMURA, TWO BROS, ALPINESTARS, SCOPRIO ALARMS
www.biohazardcycles.com
