new license plate relocator from evoluzione cyclesports - BMW S1000RR Forums: BMW Sportbike Forum
Go Back   BMW S1000RR Forums: BMW Sportbike Forum > Supporting Vendors > Vendors Deals and Specials.
Old 08-05-2010, 12:51 PM   #1 (permalink)
Site Sponsor
evoluzione's Avatar
Default new license plate relocator from evoluzione cyclesports
we would like to introduce our new license plate relocator for the s1000rr. this anodized 5052-h2 aluminum bracket was designed specifically for the new bmw superbike and bolts securely to the factyory mounting points (requires no modifications, drilling or cutting wires). our kit was engineered to properly mount the stock factory turnsignals as well as the factory license plate light. installation is easy with detailed instructions and each kit includes everything needed. removal for trackdays is also very simple - three bolts and one factory connector.
we have started shipping these kits and the retail price is $95.
regards,
ken zeller
president - evoluzione cyclesports
www.evoluzione.net
951.639.0967
evoluzione is offline   Reply With Quote
Old 08-05-2010, 03:12 PM   #2 (permalink)
URBAN LEGEND's Avatar
Can you post better pictures. I am in the market right now.
11 Kawasaki ZX10R
11 BMW 550i
URBAN LEGEND is offline   Reply With Quote
Old 08-05-2010, 05:44 PM   #3 (permalink)
Site Sponsor
evoluzione's Avatar
here's the picture from our web site:
here are two different shots on the bike:
regards,
ken zeller
www.evoluzione.net
951.639.0967
Old 08-06-2010, 09:37 AM   #4 (permalink)
Got it. Thanks.
11 Kawasaki ZX10R
11 BMW 550i
Old 08-10-2010, 05:52 PM   #5 (permalink)
Site Sponsor
evoluzione's Avatar
here is a direct link to order the relocator bracket.
click here: s1000rr plate relocator
regards,
ken zeller
www.evoluzione.net
951.639.0967
Old 08-17-2010, 12:54 AM   #6 (permalink)
Hello Ken,
today I ordered one of these license plate relocator brackets. Looking forward to installing it once it gets here. I have a question, though, I thought you may be able to answer:
looking at the factory fender setup and the wiring to the turn signals/license plate light, and comparing it to the Evoluzione's, won't the factory wire harness be 2-3 inches too long? If that's the case, will I be able to push back into the tail piece so as to hide the excess length? Looking at the pictures of the naked S1000RR you provided on this thread, i don't see any unsightly excess black wiring behind the relocator bracket, so I'm assuming there must be a way to hide the wire.
Thank you.
acm_s1krr is offline   Reply With Quote
Old 08-17-2010, 02:40 AM   #7 (permalink)
The excess harness is easily pulled into the under seat area. I like the fact that this is a no cut install--the original harness is used and no cutting/splicing is required. From what I have seen this is the only one. I have also noticed that the ones that have an LED license plate light don't light up the plate very well. The LED is very sharp and is not diffused like the filament bulb. One less excuse for the police to pull you over. "I pulled you over because I couldn't read your registration. Since I've got you here, is that exhaust legal?" Groan.
Old 08-17-2010, 02:54 AM   #8 (permalink)
Devyl's Avatar
My S1000RR is track only so no license plate holder needed but if it were needed, I highly recommend Evoluzione's products! (I have his license plate relocators on both my K1200R and HP2 Megamoto)
Devyl is offline   Reply With Quote
Old 08-17-2010, 07:34 AM   #9 (permalink)
I like the look of this - can you confirm if this will fit an Aussie 184mm wide x 99mm high number plate?
gmk2 is offline   Reply With Quote
Old 08-17-2010, 07:56 AM   #10 (permalink)
Godzilla's Avatar
I like the look of this as well. Does it fit a UK plate?
Do you export to the UK and how much tax will I need to pay?
Thanks in advance.
