Gilles Factor-X Levers Installed - BMW S1000RR Forums: BMW Sportbike Forum
Go Back   BMW S1000RR Forums: BMW Sportbike Forum > Supporting Vendors > Vendors Deals and Specials.
Old 06-04-2010, 01:26 PM   #1 (permalink)
Default Gilles Factor-X Levers Installed
First shipment that hit the USA just arrived, as promised we test fitted them on our Project Bike and as expected both the clutch and brake lever went on without any issues, all functions remain the same on brake and clutch with no modifications needed.
Took 5 min. each side to install.
They are slightly shorter then stock, great feel/fully adjustable and come with a 5 Year Warranty.
Gilles Factor-X Levers Installed-brake-mounted.jpg   Gilles Factor-X Levers Installed-brake-black-double.jpg   Gilles Factor-X Levers Installed-clutch-lever-black-double.jpg   Gilles Factor-X Levers Installed-clutch-mounted.jpg
Shift-Tech-Carbon is offline   Reply With Quote
Old 06-04-2010, 09:12 PM   #2 (permalink)
///ACS330Ci's Avatar
Hey Guido, can you please post picks of min and max adjustability (nearest and furthest from the bar) of the clutch lever? Also, can you check that there is functionality in the closest setting? Thanks buddy
///ACS330Ci is offline   Reply With Quote
Old 06-04-2010, 10:36 PM   #3 (permalink)
You caught me at the last second, just dropped of the bike after a quick ride but don't have the good camera on hand so here all I can manage right now with the cheapo camera.
Here the pictures in the following order.
Clutch out
Clutch out closeup
Clutch in
Clutch in closeup
Everything still functions correctly.
Gilles Factor-X Levers Installed-clutch-out.jpg   Gilles Factor-X Levers Installed-clutch-out-closeup.jpg   Gilles Factor-X Levers Installed-clutch-.jpg   Gilles Factor-X Levers Installed-clutch-closeup.jpg
Old 06-04-2010, 10:38 PM   #4 (permalink)
Here the brake side-
Brake out
Brake out Closeup
Brake in
Brake in closeup
Gilles Factor-X Levers Installed-brake-out.jpg   Gilles Factor-X Levers Installed-brake-out-closeup.jpg   Gilles Factor-X Levers Installed-brake-.jpg   Gilles Factor-X Levers Installed-brake-closeup.jpg
Old 06-04-2010, 11:06 PM   #5 (permalink)
Thanks
Old 06-05-2010, 09:39 PM   #6 (permalink)
Anytime.
Hope you were able to see what you are looking for.
