Originally Posted by DrIoannis
Some questions.How do you install them(glue or bolt)?What do you put under them so that there wont be scratches from vibrations?Are they thick enough (mm?) to withstand a crash?What is the price for the the set?
This is what's underneath, kevlar
I use seveal layers of kevlar/carbon fiber material on the inside and or outside as it offer better abrasion resistance then carbon fiber. I don't always use the yellow sometimes it is different colors but it all does the same thing.
I supply some little spacers that go behind the bolt holes and bolts that keep it where it needs to be. I also would suggest using some high temp silicone and squirt some in there when installing to help keep a nice snug fit and allow for some more cusion and protect against scratches too
$150 for a set and i can do them is a few outer material choices too
regards Mark
