Safety Wiring Oil filter, Drain plug and Filler.
As we have been doing track days I am slowly starting to safety wire the most important parts on the bike.
Oil filler is easy, drill 2 holes around 1/16 of an inch, then drill the clutch cover bolt closest to the filler. This one was aluminum!! It is the OEM Bolt!!
Oil drain plug is a little tricky as it is very thin on the edge, I used a smaller drill and used a Bridgeport Mill, a drill press would be OK as well. I use a larger drill to start the hole as a larger drill does not move around when starting.
Oil filter, Just a hose clamp here, pushed up against the boss on the engine assures it will not rotate loose.
