Originally Posted by BSR-1
So the ECU didn't richen the fueling to compensate for the full system?
How much difference with the PC? are you running the "off the shelf" mapping?
I don't believe this or any other bike is able to adjust fueling for an exhaust change. The o2 sensors are strictly to overcome emission regulations and only operate under the narrow range of conditions dictated by such regulations (eg cold starting, idle and cruising). This is as I understand it at least.
When I first installed the PC I used a map from the Dynojet web site. It was OK. A creamier midrange was the most noticeable improvement.
I Decided to go with an autotune rather than dynotune just out of interest. My bike is a track bike and it is now hitting the limiter on a short straight were it didn't before, I can also pull a gear higher through a particular corner complex so it would seem I have picked up a bit of mid and top end. Unfortunately it hasn't manifested in quicker lap times yet
I still have that bog/surge thing cracking the throttle midcorner. Not everyone seems to pick it up and I am slowly getting used to it but I'd love to now how to eliminate it.
