Break in rev limit? - BMW S1000RR Forums: BMW Sportbike Forum
Old 10-14-2011, 11:48 PM   #1 (permalink)
BSR-1's Avatar
Default Break in rev limit?
I've already searched but can't find the info.
The dealer wants me to pay 200 for the 600 miles service so they can remove the break in rev limit.
What's the trick? Can't be too hard.
Old 10-15-2011, 12:40 AM   #2 (permalink)
AL BEANS's Avatar
trick is simple........... ride it as specified for the first 600 miles and then go get the service done, and stop being cheap ............good luck
AL BEANS is online now   Reply With Quote
Old 10-15-2011, 12:42 AM   #3 (permalink)
They actually do more than just remove the limiter. As far as you removing it by your lonesome good luck with that, I have yet to see anyone accomplish that. They use the computer to "unlock" it. What is included in the $200 is
(+) Setting service-due date and countdown distance
(+) Deleting limit for running-in rpm
Deleting limit for running-in rpm (with GT1 or SSS)
Start the CIP program.
Select the series.
Switch to the "Vehicle" mode.
If necessary, click on "Start update" to acknowledge the status report, accept the measures plan and click on "Conclude" to close the final report.
Select the "Maintenance" menu.
Select the "Delete nENG max" submenu.
Run the measures plan, read through the final report and click on "Conclude" to close.
Terminate the CIP session.
Delete the limit for running-in rpm (with ISTA/P)
Delete the limit for running-in rpm as follows:
Start the session.
At the "Have control units been replaced?" prompt, click on "No".
Select the "Vehicle actions" menu.
Select the "Delete nENG max (rpm limiter)" option.
Select "Compute measures plan".
Accept the measures plan and read through the final report.
Terminate the session.
(+) Reading fault memory with BMW Motorrad diagnostic system
(+) Engine-oil change, with filter
(+) Readjusting steering-head bearing
(+) Checking brake-fluid level, front brakes
(+) Check the play of throttle cable
(+) Checking fastener of clutch lever fitting
(+) Lubricating clutch mechanism
(+) Checking clutch cable and clutch-lever play
(+) Lubricating side stand
(+) Checking coolant level
(+) Checking tyre pressures and tread depth
(+) Check the lights and signalling equipment
(+) Function test, engine start suppression
(+) Final inspection and check of roadworthiness
(+) Confirming BMW Service in on-board documentation
Do a google search and you can find this info.
Damon is offline   Reply With Quote
Old 10-15-2011, 10:20 AM   #4 (permalink)
Originally Posted by Damon View Post
As far as you removing it by your lonesome good luck with that...
You actually can remove the rev limiter yourself if you have a GS-911 tool. Hard Racing on the forum sells em.
Old 10-15-2011, 11:05 AM   #5 (permalink)
AL BEANS's Avatar
Is just removal of the limiter or full rom refresh with the gs tool 1000?
Old 10-15-2011, 11:33 AM   #6 (permalink)
yangins's Avatar
i paided 141 plus tax for my 600mile. Included Amsoil oil change also.
Previous bikes
01 Ducati S4
02 Aprilia RSV R
yangins is offline   Reply With Quote
Old 10-15-2011, 12:27 PM   #7 (permalink)
The most important part of that service is adjusting the steering head nut.
RansomT is offline   Reply With Quote
Old 10-15-2011, 04:58 PM   #8 (permalink)
BSR-1's Avatar
Thanks guys!
"Most" of those replies were helpful!
Old 10-15-2011, 09:35 PM   #9 (permalink)
BSR-1's Avatar
I choose to spend my money wisely.
If I can do the work myself and save the money for something else that I'd rather have, I'd call that smart.
You can call it whatever you want.
Old 10-15-2011, 10:54 PM   #10 (permalink)
Triple Threat's Avatar
The 600 mile service was $262.
The 6,000 mile service was $325, which included oil & brake fluid changed and new air filter.
Labor is $100 per hour at this shop seems a little high to me. Both repairs were done in a California BMW shop.
Triple
2010 BMW S1000RR
2009 Aprilia Dorsoduro
2006 BMW R1200RT
