bike is DOA - BMW S1000RR Forums: BMW Sportbike Forum
Old 10-03-2011, 10:58 PM   #1 (permalink)
Default bike is DOA
went for my 3rd ride the other day, about 50 miles in I felt the bike just wasnt right. I pointed the nose for home and then noticed that when I pulled in the clutch at highway speed she died. let out the clutch and she fired back up so I babied her towards home. Got about 5 miles from the house and she shut down at 65mph like someone turned off the key. now she wont fire at all. turn the key on and can hear the fuel pump, hit the start button and I get the lights diimming and a click of the starter and no joy. calling the dealer in the morning.
2010 MotorSport
2008 K1200GT
2008 WR250R
Karlb is offline   Reply With Quote
Old 10-03-2011, 11:10 PM   #2 (permalink)
Have you tested the battery, or its connections?
JACOX is offline   Reply With Quote
Old 10-03-2011, 11:11 PM   #3 (permalink)
capecod1000rr's Avatar
Ouch man. I hope u can get this squared away. What year do you have?
capecod1000rr is offline   Reply With Quote
Old 10-03-2011, 11:14 PM   #4 (permalink)
Battery or connection problem for sure.
stator maybe..... but would be weird for a 2010 bike
Sprocket is offline   Reply With Quote
Old 10-04-2011, 02:04 AM   #5 (permalink)
H-2 CHARLIE's Avatar
I had a mystery shut down again last week ... im thinking the kick stand switch
SO.CAL.we ride all year long
H-2 CHARLIE is online now   Reply With Quote
Old 10-04-2011, 04:42 AM   #6 (permalink)
S&Kmotorrad's Avatar
Agreed on the battery Karl!!!
Same happen on the k13s.
S&K Motorrad
Live2Ryde
2011 S1000RR
2009 K1300S
Old 10-04-2011, 07:32 AM   #7 (permalink)
thought the battery also, checked it seemed suspect.
v=12.6, key on v=12.3 hit starter v drops to 8.6-9 figured this was a battery that wouldnt handle a load
ordered a new one, no joy new battery arrived last night, does the exact same thing, also used a jumper and grounded battery to frame to check if a grounding issue, no joy.
when purchased bike had PCV and akro so need to try removing the PCV from the equation and see if that changes anything
2010 MotorSport
2008 K1200GT
2008 WR250R
Old 10-04-2011, 09:35 AM   #8 (permalink)
Check your starter wire! When mine was new within about 100 miles the bolt rattled out of the starter and the cable was bouncing on and off the connection causing the same problem you are having. I pulled the seat and tank off and you can see the connection directly in the middle of the bike on the top of the motor. I used loctite on the bolt this time.
2010 BMW S1000RR White/Red/Blue w/ all options
lrn5000 is offline   Reply With Quote
Old 10-04-2011, 04:30 PM   #9 (permalink)
it must be the akra and PCV problem, here, i do you a favor, i will take them away from you and you should be in joy at no time...
S&K Motorrad
Live2Ryde
2011 S1000RR
2009 K1300S
Old 10-04-2011, 07:38 PM   #10 (permalink)
took her to the dealership today, last word I got was they couldnt get the ecu to talk to their comp????? will call in the am and see where it is at.
2010 MotorSport
2008 K1200GT
2008 WR250R
