here is the answer to the Questions i asked and there answers .. very impressive and a definite buy for those who like the slight advantage over the stock QS ... if i may add very impressive customer service
1. I have the full option S1000RR with quickshifter.. My question is what will I gain from using your Quickshifter VS the OEM QS!?
The RL is much higher technology and to be blunt, works… The same HM technology in the RL is used by the top BMW race teams, we think that helps to say about all there is on OEM vs our design…
2. Can I adjust the shift timings like I can do with the bazzaz QS!?
The HM technology if far beyond that. Other companies use extended shift times to compensate for the inefficiencies and flaws of mechanical switch designs. The HM Strain Gauge sensor and DSP controller used in the RL, like the HM PLUS, does not need this.
3. Do I need to turn the OEM QS so it won't interfere with this QS or is it just plug and play!?
No, plug in and go…
4. Has any1 used it before on s1000RR!?
The RL has only been available for a couple of days, so not sure here in email if anyone has installed one yet. But the HM PLUS is considered throughout the WORLD as the finest shifter you can possibly install, and the RL is all the technology of the PLUS, only missing the “extra’s” that nobody uses anyway on the modern sportbikes.
So in answer to your question, yes in terms of technology. The PLUS is well known, and very shortly EVERYBODY will know about the Annitori RL…
5. Will the OEM shiftrod work with it for regular shifting !? If not can u provide me the price for your shiftrod!?
No, you need a 50mm shorter rod then what is on your bike to allow the RL Strain Gauge sensor (which is 50mm long) to be attached… Shift rods are $21.95…
Hope this information helps, please let us know if we can assist you further with any other questions…
Annitori Distributing
Annitori -- MICRON
1-888-963-1212
