Originally Posted by YELLOPER1L
Allegedly, at 155mph the ram air generates 7bhp.
This sounds a little high to me. There is a relatively simple equation that relates speed to ram air pressure:
ram air pressure = 1/2 x air density x airspeed squared
For english units,
ram air pressure in psi = mph squared x .0000176
Plug in 155 mph and you get .42 psi.
Atmospheric pressure is about 14.7 psi so if you're doing 155 mph your engine should be seeing about 15.1 psi, or about equivalent to a turbo with a 3% boost. If the engine doesn't experience any extra loses due to the boost then power should increase about 3%. On a 180-hp engine, that would be about 5 extra hp, pretty close to the number above.
Because of the velocity-squared term, things do heat up when you're going seriously fast. At 200 mph, you could theoretically expect a 9-hp boost, and if you could go 250 mph, it works out to 13 hp. By the same token, the effect is negligible at sane speeds - at 75 mph, its 1 hp.
This all assumes the ram air system works absolutely perfectly, recovers absolutely 100% of the air's velocity as increased pressure, and there are no losses in the intake or engine due to the boost. In reality, I don't think any of this is true, so you'd expect to get less boost, perhaps much less boost. And the S1000RR's ram air system doesn't really seem to me to be very well designed to capture the ram air effect - I think its main purpose is simply to feed cool air to the intake. In reality, the boost you get is probably a few hp at the bike's top end and not much else.
It would be very interesting to instrument the pressure at the S1000RR's throttle bodies and ride the bike at various speeds with different intakes. Without such data, its pretty much speculation. But the above numbers determine the theoretical limits of what is possible. And it ain't that much.
