Originally Posted by RansomT
Wish you could post the TQ numbers. I could tell more.
and there is something wrong with probably both the flash/ECU and the dyno. If you compair the AFR at 6500 and 8000, you are going from 12.2:1 to 10.6:1. 12.2:1 the bike will make "o.k." power at 10.6:1 it should fall flat on it's face, however the power curve doesn't reflect that at all. When you approach 11:1 AFR, the bike will smoke (black) .... does the bike smoke?
It does fall away sharpish on the top. Up to say 10k it is there or there abouts. then it just does not pick up even though the curve looks normal. That is why I thought there is something wrong with the flash. But a second dyno will confirm for sure. If the others with the AKra and not map are making 174 on that dyno, he should make 180.
Just a thought, what fuel was in the bike at the time of the dyno?
