HM Quickshifter Plus Install - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-06-2011, 01:10 AM   #1 (permalink)
Default HM Quickshifter Plus Install
Anyone out there install an HM Quickshifter plus with a power commander already installed on the bike? I've done a ton of research online but can't seem to find any info on install and the manual isn't exactly specific for BMW's and is pretty vague.
Thanks,
Chris
cts488 is offline   Reply With Quote
Old 05-06-2011, 06:30 AM   #2 (permalink)
Nigel's Avatar
I woud also be interested in the results.
N.
Old 05-06-2011, 08:34 AM   #3 (permalink)
RyanITV's Avatar
Does the HM unit just plug in and replace the stock sensor? After messing mine up (loosened the nut by the QS when adjusting the rod), I can't get the stock one to work at full-throttle above 3rd gear.
If I've got to replace the sensor, I figure I might as well upgrade for the same $$$.
Ryan
Check out my 2010 S1000RR Race Bike Build Thread...
Thanks to: DecalGirl | NESBA | Performance Cycleworx | Alpha Racing | TrackWraps | SpeedWerks
RyanITV is offline   Reply With Quote
Old 05-06-2011, 08:46 AM   #4 (permalink)
Nigel's Avatar
Ryan
Yes, it is supposed to be plug n play.
N.
Old 05-06-2011, 11:28 AM   #5 (permalink)
Can't help with the HM,but I've just ordered a Cordona Quickshifter kit for the S1000RR which is full plug and play,fully adjustable,strain guage technology etc. and totally independent to the rubbish OE electronics.And a bit cheaper than the HM too.
Hopefully this will cure my gearbox problems.
Old 05-06-2011, 11:55 AM   #6 (permalink)
HM is plug and play, easy to swap back and works a treat. My tuners use them and Translogic and have not had any units back with any problems either on the bike or the units themselves.
I didn't do the install myself but it looks very straightforward. Easy to tweak delay times if you need to, though I had mine set up on the dyno and it was perfect straight off.
dazoo is offline   Reply With Quote
Old 05-06-2011, 12:29 PM   #7 (permalink)
RyanITV's Avatar
I ordered an HM for delivery tomorrow so I can get back on the track Sunday. Nothing was more frustrating that spending half the front straight fighting the shifter...
We put the Factory Pro spring as a preventative measure during the build. I've only had one false neutral and I attribute that to my foot sliding around on the worn out pegs on the Woodcraft rearsets, haven't had one since switching to the Attacks.
Ryan
Old 07-02-2011, 12:53 PM   #8 (permalink)
1000RR Bahrain's Avatar
Any updates on the HM quickshifter?
Old 07-03-2011, 12:13 AM   #9 (permalink)
Thugsfatboy's Avatar
I installed the HM into the PC and it didnt work ,what we found out later after abusing the HM dealer is that you need the PC expansion module as the PC only affected the primary injectors so your it was not killing all the injectors,i now have the HM loom which attaches to all 8 injectors ,was hoping that BMW woulkd fix teh problem but appears not so fitting HM and Pro spring,due to work commitments wont be riding it until end of July at the track
Old 07-03-2011, 01:18 PM   #10 (permalink)
2003csl's Avatar
has any one tried the pc quick shifter on the s1000rr? i rode my friends cbr 1000 with one and was surprised how well it worked. i thought it shifter smoother than my factory quick shifter
cycle therapy is the best therapy
2003csl is offline   Reply With Quote
