Originally Posted by jkleinha
That looks like a nice chain you recommended. I guess I could get over the gold color if that was the best chain you could buy.
Now I guess my next question is, how do I size it for a stock replacement? How many links (hope I don't need to count them), etc?
The stock chain is a 525. Many liter bikes come with a 530... and many folks convert their bike to a 520. Each size basically has to do with the width of the chain... the lower the number, the skinnier the chain (not by much, but a little). So the lower the number, the less it weighs, the less it weighs, the less unsprung mass, the less unsprung mass, the better the acceleration. Now the question is will you notice a difference (in acceleration) between a 525 and a 520... and do you want to change your sprockets too (from a 525 to a 520). As a general rule, the bigger the number, the more strength the chain has too... but some of the 520's out there are pretty darn good! You will also hear about Pitch... that is the distance between rollers... it's the same for a 520, 525, and 530... Basically if you put the first number in the three digit string over 8... that is the distance between rollers. So a 530 chain is 5/8" between rollers. A 630 chain is 3/4" (6/8ths) between rollers.
Here's some further info on the pitch and widths of chains:
520 5/8 inch pitch, 1/4 inch wide
525 5/8 inch pitch, 5/16 inch wide
530 5/8 inch pitch, 3/8 inch wide
As for sizing the chain... you can simply start at some location on the chain and either count the rivets (number of links) or count the number of side/outer plates. If you do the latter, just multiply that by 2 and you come up w/the number of links you need (the number of links you need should always be an even number). Remember to buy a new master link and a chain tool to put it together... having an extra master isn't a bad idea either.
