My Dyno Today - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-03-2011, 07:57 PM   #1 (permalink)
V8M3's Avatar
Default My Dyno Today
This is the dyno sheet from my bike this morning. Performance changes are Devil Exhaust, PCV/AutoTune, PAIR valve blocked. It was at a Ducati dealership. I was running 91 octane/ 10% ethanol. I am at 4400 feet above sea level and it was 55 degrees F. The technician told me that their dyno had a 10% correction and that their numbers are always low. He said that given correction my rwhp was 194.68.
The first run was with no changes to PCV/Autotune at 168.11 RWHP, the green run was at 13.8, the red run was at 13.6. There were other runs from a low of 13.2 to the high of 13.8 where the power started to drop off. He said there is great torque and the curve is amazing.
The 2K - 4K range he felt would be corrected over time by the AutoTune. He did not change any numbers in this range. He did double check my AutoTune and showed me how to effectively use the device.
I ran the dyno more out of curiosity, but I was happy to have the technician's input.
Any thoughts?
Old 05-03-2011, 11:19 PM   #2 (permalink)
Send a message via MSN to zer0code
Wish i could help you mate, but i dont have a clue cause your bike is modded. What i've seen, considering your mods, got a friend with everything u have but AT, he got 215rwhp, using Akra full/pcv/pair blocked.
Not sure what CF was used on his dyno, i'd bet on iso, we dont use sae here nor din.
What do you feel when you ride your bike? is it good enough, strong enough? u think u can get more from it?
zer0code is offline   Reply With Quote
Old 05-03-2011, 11:26 PM   #3 (permalink)
Originally Posted by V8M3 View Post
...He did double check my AutoTune and showed me how to effectively use the device...
Can you expand on this part?
Old 05-03-2011, 11:31 PM   #4 (permalink)
V8M3's Avatar
The bike is well beyond my means. I am just looking to see where I am at with some mods. There was a change in throttle response getting on the freeway that was noticeable.
Old 05-03-2011, 11:37 PM   #5 (permalink)
V8M3's Avatar
Basically loaded AF ratios into PCV and showed me how to use AT to adjust. Made sure that AT was activated and monitoring PCV. I had loaded a map using akra values with stock filter. This was tweaked.
Old 05-04-2011, 06:42 AM   #6 (permalink)
Sextaafondo's Avatar
Nice curve and power. You'll be able to improve that even more with time.
If you go down to sea level you'll get scared
Pablo
05 ZX-10R
Sextaafondo is offline   Reply With Quote
