Lean Angle Sensor...what if... - BMW S1000RR Forums: BMW Sportbike Forum
Old 04-14-2011, 08:29 AM   #1 (permalink)
Default Lean Angle Sensor...what if...
So, My bike has a very slight twist to the subframe from when it was damaged before I got it.
What if the right side is about a quarter inch down on the very aft right and basically straight by the time you measure at the rider's seat, would this then make the bike think it's leaned over a little to start with?
I see the white box that has the sensor in it and wonder if it's going to read a couple degrees lean from what is upright really, based on this tiny difference in the level of the subframe...
Any ideas folks?....I am going to tweak the subframe back to as close to normal as possible.
Thanks, Chris
CRA 75E
2010 #7 NOVICE
Britracer is offline   Reply With Quote
